Old 03-23-2011, 10:57 AM
BJSwart is on a distinguished road
Fanuc 18i MB
This control is new to us usually we run the 18MC. I am wondering how to assign a specific program number to a file we are pulling off a server. The control always seems to assign O0001 and we have probing programs that stay on the machine and they are O0001 -12. Is there a way to specifically assign a program number to a file? For example O0100? On the older control we can enter O100,SV1.TAP and it will load the file as program O0100.
I hope this makes sense.
Thanks.
Old 03-23-2011, 09:03 PM
stevo1 is on a distinguished road
Does it always assign O0001 as the program number even if you make the file name in the server O1234 as an example?
What you make the file name may not matter depending on the software you are using to transfer programs. What matters is the beginning part of the program in the actual file. For fanuc it usually starts with O or : but O is most common so in the beginning of the program label it O1234 and see what it does.
Stevo
Old 03-23-2011, 09:58 PM
dcoupar's Avatar
Thanks.
Are you using RS232 or Data Server, or what?
I've never seen the format O100,SV1.TAP used when loading programs into CNC memory.
The 18iM-B and 18M-C instructions for loading a program through RS232 are identical.
Old 03-24-2011, 05:57 AM
Stevo
We are transferring files through the data server. We can see the host folder with the files in it. All of our programs start with:
O**** (depending on the program number)
Thanks.
Old 03-24-2011, 06:00 AM
We are using the data server. On the 18mc we get the file onto the control we can load it as O100,SV1.TAP and it will load the program as O0100. Sorry I am not a Fanuc expert.
GE Fanuc & FANUC proprietary posts CNCadmin Fanuc 44 01-05-2012 08:54 AM
Need Help!- Difference between Fanuc 0i-MC and Fanuc 0i-MD humak16 Fanuc 12 12-29-2011 10:49 PM
FANUC & GE FANUC Repairs RRL Product Announcements & Manufacturer News 1 04-17-2011 11:50 AM
can fanuc ac digital servo amplifiers be run by a controller other than fanuc? js412000 Servo Motors and Drives 5 03-09-2011 09:11 AM
