Old 03-23-2011, 09:34 AM
parametric.ms is on a distinguished road
DC Servo Vibrates on Fanuc 6M
I have several problem with fanuc 6MB at Yamaguchi MC
1. when I move X axis to (-) direction it goes smooth. but if I move to opposite (+) direction, the servo vibrates so hard.
2. its happen to Z axis too with contrary case. when it goes up (+ direction) looks smooth. but if I move to minus direction, it just move a little then alarm comes up. (430 Z Servo)
I've compared whole parameter with Y axis with normal condition,but no luck. its still the same. Maybe I miss some parameter
What should I check to fix that problem?
Thanks in advance
PS : DC Servo Motor type 5M with VCU A20B-0009-0320
Old 03-24-2011, 07:06 AM
where is Al The Man and Dan Fritz ? I need you here ASAP
I swap both servo and drive with Y axis but the problem still on X axis
I checked the DIAG 713 bit 4-5 works fine for Pulse coder
Old 03-24-2011, 08:37 AM
3d GEORGE is on a distinguished road
Servos vibrate.
We had similar problem with our 6M Pratt & Whitney VMC machines. We discovered that if you can, remove the servo end cap. This should expose the servo encoder. Don't confuse with the encoder on the ball screw. Spray servo encoder with electronic cleaning spray available at Radio Shack or Best Buy. Cycle servo manually several times. Worked for us.
Old 03-24-2011, 08:44 AM
greenery_fr is on a distinguished road
First check +15 volt -15 volt and +5 volt on your Master PCB. If it Ok may be you had problem with master PCB. The main problem is in hybrid IC APC06
Old 03-24-2011, 09:29 AM
Is it Freq to Voltage Converter IC? where is the location on master PCB?
Old 03-24-2011, 09:32 AM
Like I describe, seems look no problem with pulse coder. It works at minus direction smoothly. But I'll double check just for make sure
Old 03-24-2011, 10:02 AM
mike-at-thorn is on a distinguished road
On the older machines with DC motors, I found that in the case of vibration, cleaning the brushes and armature usually solved the problem. The brushes are located at 90 degree increments around the motor housing under rubber caps. Keep track of which hole the brushes came out of. Blow them off with clean dry compressed air and then clean the armature with a pencil eraser. If it's the problem, the eraser will come out black and sooty. Blow thru the brush holes with compressed air, but try not to breath the dust.
Old 03-24-2011, 10:22 AM
ITT-Student is on a distinguished road
This is an A06b-6047-hxxx servo drive correct? Are both servos identical?
Old 03-24-2011, 10:43 AM
3 axis are identical. A20B-0009-0320. I already swap whole unit (drive & motor) X to Y but had no luck still vibrating on X. I haven't swap with Z axis
Old 03-24-2011, 10:48 AM
the 1st thing that I done was disassembled motor from ballscrew. checked the carbon brush, remove and clean armature from dust with clean dry compressed air.but nothing change even I swap the motor
  #11   Ban this user!
Old 03-24-2011, 11:11 AM
So the problem didn't move with the drives or motor? If this is the case then maybe you have some "noise" near the axis's or cabling? Do you have manuals on the fanuc 6?
  #12   Ban this user!
Old 03-24-2011, 11:16 AM
yes precisely... did you mean noise that affected to command signal? I have the manual doc with scan quality
can fanuc ac digital servo amplifiers be run by a controller other than fanuc? js412000 Servo Motors and Drives 5 03-09-2011 09:11 AM
Need Help!- Motor just stalls and vibrates! prcdslnc13 Stepper Motors and Drives 12 12-02-2010 06:58 AM
Need Help!- fanuc 5m servo skippyfix Servo Motors and Drives 6 09-03-2010 12:50 PM
Xylotex, steptest.exe, vibrates, ticks but no movement RedLabel Xylotex 0 06-30-2007 08:15 PM
AMC amp with Fanuc servo Drew Fanuc 0 02-07-2007 01:54 PM
