Old 03-21-2011, 01:49 PM
samu's Avatar
samu is on a distinguished road
spindle alarm 409
control:0-MD
alarm 409. on the spindle amplifier, led indicate number 12.
what does it mean? how to fix it?
Old 03-21-2011, 01:53 PM
Al_The_Man's Avatar
Ouch ...$$$.
Unfortunately this usually due to the IGBT transistors shorted.
The firing board should also be checked before a blanket replacement of the semi's, if this is in fact the case.
Old 03-21-2011, 02:00 PM
samu's Avatar
how to check if it'is the IGBT. Can i replace only the transistor or it is easier to ship the amplifier to fanuc and buy a new one?
Old 03-21-2011, 03:03 PM
samu's Avatar
could it be caused by anything else outside the spindle amplifier module. If I change all the module, can i be sure that it will fix my proplem. Do you have a shematic of the amplifier(A06B-6082-H211#h512) What is the firing board?
Old 03-21-2011, 03:07 PM
Al_The_Man's Avatar
The IGBT can usually be checked with a meter for shorts, I have replaced them only to have them blow as soon as power up, they are not cheap, so now I just send them in for a complete check including the firing board.
There is North American Industrial in Mississauga that repair them.
Old 03-24-2011, 06:45 AM
samu's Avatar
changed igbt and it works again.
Old 03-24-2011, 09:31 AM
Al_The_Man's Avatar
Lucky you.
Old 03-27-2011, 06:12 PM
Sandro Martins is on a distinguished road
O Alarm 409 no spindle serial se refere a comunicacao entre o spindle e a fonte ou o spindle e o cnc.
obrigado
1992 VF2 Alarm 123 spindle Spindle Drive Fault dafowfidy Haas Mills 15 05-14-2012 01:32 PM
Need Help!- 750 ALARM SPINDLE-1 ALARM DETECT (AL11) PICMAN Fanuc 9 03-27-2011 06:14 PM
spindle alarm 5 cnt CNCzone Club House 0 12-02-2009 10:32 PM
Need Help!- spindle alarm bhupinder Fanuc 1 01-31-2008 01:24 PM
Spindle Alarm phoodieman Daewoo/Doosan 2 03-16-2007 07:06 PM
