I have a CNC Glass cutter with a faunc 0-m controller. The problems I see is when I try to use Cutter Comp(G41), scaling (G51) and macro variables (#). both G41 and G51 will give me a 010 P/S error for unusable g-code command. Example: G51 P2 or G41 D11 If I try to manually edit a program on the machine it will not let me enter the "#" character. The EOB key will only enter "," ":" and "/". If I try to send a program to the controller via DNC with the # in it, I get a 087 P/S error for data input is not stopped after 10 characters are read and stop command is specified. Example: #100=5 What I would like to know is if there are parameters that enable/disable these g-code functions or a macro B enable. |
| PM sent. Your 087 alarm could be you have not set for XON/XOFF handshake. Al.
| Tags |
| fanuc 0-m, g41, g51, variables |
| Need Help!- My Milling OKK with fanuc 6M can't recognize G-code & M-code | nessei | Fanuc | 4 | 03-29-2011 08:39 AM |
| fanuc program code vs. Haas code | sixty8frbrd | Fanuc | 6 | 03-10-2011 09:05 PM |
| Converting Fanuc G code to Seimens 840D G code | Jasbinder | Siemens Sinumerik CNC controls | 2 | 02-20-2011 10:02 AM |
| Newbie- Takeout Unused G Code commands in Mastercams Generated G Code | shneek | Mastercam | 8 | 12-15-2010 02:32 PM |
| looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft | troyswood | Ability Systems - LPT Indexer and G-Code | 2 | 12-24-2006 09:21 PM |
