So, have a OLD lathe, was retrofitted a few years back with a Fanuc 21i (GE). Operator/programmer was trying to use a G71 roughing cycle, looked correct to me, but was only doing one pass to finish size. I changed to a G73, and the roughing cycle worked, although the book shows more of a copy cycle, it looked just like a G71 does. Same values all around, just altered the G71 to a G73. The G70 line does not run the finish pass at all. Tried a G71 in place of the G70, and it switched the machine to metric?! Am I missing something or do we have corrupted software or something else i'm missing. Been on Fanuc controls for 20 years, but mostly just basic programs and fixing them. |
| I don't have the manual in front of me but there is a parameter setting for using G70 and G71 for inch and metric instead of G20 and G21. I came across this on a 15series I was setting up a few years back and never knew it existed until then. Took me a few days of digging until I figured it out. I am not sure if the 21i series has this parameter but based on what you stated I would almost bet that is the issue. IIRC it was under the section of programming/edit. Stevo |
| Difficult to believe. Syntax is different. Post your program. It was possibly a G73 cycle which somebody "modified" to G71. Is it one-block or two-block format? |
| Outputting Common variable values into a program (with automated program number) | yaji63 | Fanuc | 0 | 12-27-2010 02:55 AM |
| tl-2 program integrity error and program data error alarm #'s 212 250 need help | CNChelp | Haas Mills | 12 | 03-14-2010 08:19 PM |
| Mazatrol Program into a G Code Program | fuzzman | Mazak, Mitsubishi, Mazatrol | 14 | 02-08-2010 03:55 PM |
| Program Restart in mid program? | Donkey Hotey | Haas Lathes | 16 | 03-18-2008 02:19 PM |
| Anyone got any basic examples of a program using a subroutine/program? | Darc | CamSoft Products | 11 | 10-08-2005 11:45 PM |
