Old 03-11-2011, 01:34 AM
joyfrankie is on a distinguished road
Unhappy AMADA NCT PEGA345Q,"G98Code"can not used
Hi,everyone:
I used AMADA NCT 345Q; 04PC control system, and now the machine can not read 'G98Code', enter 'G98Code' program, press the start button. Alarm system will appear '911 '. Machine safety ground. Other procedures can be used normally: G93, G90, G66, G28, G79, G37 and so on can be. Come Help me!
Old 03-11-2011, 03:43 AM
Superman's Avatar
Superman is on a distinguished road
Did you use "G98" just by itself ??
Old 03-11-2011, 08:28 AM
I has used'G98' running by itself. but '911'alarm stll appear.
How to "offset" Double sided PCB if I don't have abolute "home" on my CNC ? Calico PCB milling 11 07-12-2011 06:02 AM
Need Help!- Thread Milling using "C" axis no "Y" on the machine tejano4life72 Mori lathes 7 07-19-2010 02:59 PM
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
Need Help!- "Warco GH Univ" V "Chester Lux Mill" JQ_Quint Benchtop Machines 37 01-22-2009 10:59 AM
