Old 03-09-2011, 09:34 AM
walshsimmons is on a distinguished road
Disable adjustable feedrate on 0M controller?
Hello,
Is there a G or M code that can disable the adjustable feedrate on a 0M controller? The operators slow the programs down to a snails pace.
Thanks,[/
Old 03-09-2011, 12:29 PM
cnc2149 is on a distinguished road
FANUC doesn't provide an M/G code to disable the feedrate override but there are a couple of methods to implement it.
1. PMC Ladder
Define an M code to activate the OVC (G126.4) bit in the PMC Ladder to disable the feedrate override. You would probably want to define an additional M code to release the OVC bit. This method requires implementation by someone with the knowledge and equipment to edit the existing ladder and burn new EPROMs.
2. #3004 System Variable
You can define an unused G or M code to manipulate system variable #3004 to disable the feedrate override. A shrewd operator can get around this. Also, #3004 is automatically reset to 0 at every power up.
The following are example macro programs to allow M50 to disable the feedrate override and M51 to enable the feedrate override. You can use other unused M codes as these are just for illustration.
Assign the M codes to macro programs:
par 0230 = 50 (M code to disable FRO)
par 0231 = 51 (M code to enable FRO)
O9020 (M50 DISABLE FRO)
#3004 = 2
M99
O9021 (M51 ENABLE FRO)
#3004 = 0
M99
Old 03-10-2011, 02:51 AM
sinha_nsit is on a distinguished road
Can just insert #3004 = 2 in the beginning of the program, assuming this variable is available on this control. And lock the program-edit function.
A value of 3 would disable feedhold also.
Tags
fanuc 0m, feedrate too slow, g codes
VSD-E disable and recovery jnnewton Granite Devices 18 11-16-2010 05:28 AM
G203v disable pin kae Gecko Drives 4 02-16-2010 07:55 PM
Need Help!- How do you disable SMI? SpeedsCustom LinuxCNC (formerly EMC2) 3 03-04-2009 03:22 PM
Need Help!- Disable FAPT F3T Pxt Fanuc 1 02-27-2008 08:28 PM
Gecko 201 disable? LEWENZ Gecko Drives 6 01-12-2007 09:24 PM
