Old 03-08-2011, 10:03 PM
69owb is on a distinguished road
fanuc 6M Mirroring issue
Hi guys
I'm trying to use the mirroring function on some of my programs.
On my control I can select the mirror function manually but there is no M or G code to call it from the program. In the manual they talk about #3005 can change the values in the Setting Data window. So i created a couple M codes M90 Mirror cancel, M91 Mirror X and Y. tied them to subprogram 9002 and 9003. I seams to work they will change the state of the values for the mirroring function. But the problem I'm running in to is when you try to run the program thru it acts like it is running in incremental mode and it doesn't really recognize the work offset, very inconsistent. So if you start the program with the mirroring off it will run your first offset fine then call the mirroring and a different offset it seams to work but if you try to run the program again it will take off in some other direction? any thoughts or ideas on what to try to make this work.
the sub programs look like this
O9002
#3005=32
M99
O9003
#3005=35
M99
then tried this
O9002
#3005=32
G20 G90
M99
O9003
#3005=35
G20 G90
M99
32 and 35 are binary code
Thanks for the help
Mirroring with Mach Cairns Tormach PCNC 11 02-18-2010 02:50 AM
Mirroring for opposite part robyc01 EdgeCam 3 08-18-2009 08:43 PM
Mirroring a fixture offset on a CNC-88 CaseyCAM Fadal 1 07-25-2009 01:24 AM
Mirroring Parts babinda01 Alibre Design 7 09-08-2008 01:02 PM
CNC Simulation for mirroring on Fanuc controllers karlis_m Fanuc 0 06-17-2007 09:16 PM
