Old 03-07-2011, 02:03 AM
KylerC is on a distinguished road
Angry Root Pass Memorization
I have an Arc Mate 120iB/10L with an R30i controller, and a Lincoln V455M welder. I'm trying to get the root pass memorization to work and the error codes that I come up with is either "pitch to small", which i adjusted in the variables, and the other error says "segment not in buffer" i know that it is recording the root pass but i cant figure out why the Multi-pass offset is throw error's up. Tried contacting the company that installed the work cell for us, but, I with no prior knowledge to any kind of robotic work cells, know equal if not more than this company, and have only worked on it for 2 years. Contacted FANUC but the company i work for wants to try their best to stay away from spending a huge amount of money for a problem so little. Im a newbie to this, but i catch on real fast!
Tags
fanuc, r.p.m., root pass memorization, thru arc seam tracking
Pass Through? Jtron5 Laser Engraving & Cutting Machines 15 02-09-2011 02:45 PM
Step over 2nd/3rd pass Sjotime DIY-CNC Router Table Machines 11 12-09-2010 12:30 AM
Problem- Bad pass ozstockman Wood Working Tooling 12 01-04-2010 01:32 AM
root access login DrStein99 LinuxCNC (formerly EMC2) 11 11-14-2008 03:54 AM
Can I run axes at different ipm on the same pass? yorttroy DIY-CNC Router Table Machines 5 01-04-2006 12:34 PM
