Old 03-04-2011, 11:48 PM
Rizaldewa is on a distinguished road
How to Dreep Feed On Fanuc 9?
anyone knows how to drip feed on fanuc 9?
parameter setting,card option,etc?
thank's a lot
Old 03-05-2011, 04:45 PM
angelw is on a distinguished road
thank's a lot
The following parameters have to be set at the control and a cable configured as shown, made or bought. The cable is simple to make; use shielded cable having at least 3 wires.
Your control should have a TAPE mode. You use this mode when drip feeding (DNC) to the control. The PC software usually has a DNC mode as opposed to just Send Mode. Get the PC side ready to DNC, select TAPE mode at the control and press cycle start to run the program. All functions such as Optional Stop, Single Block, Feed Hold, Block Delete ect, all work as per normal. The only limitation is that if the program uses Sub Programs, the Subs have to be registered in the memory of the control.
Regards,
Bill
Parameters
311 = 10 (4800 Baud Rate) Starting Point
340 = 2 Input Device
341 = 2 Output Device
Control Set Page Settings
I/O = 1
ISO Format = 1
Cable pin out for Xon Xoff handshake
Machine End--------------------PC End
DB25 Male Connector----------DB25 Female-------DB9 Female
1 (Chassis ground)--------- (Not connected)--- (Not connected)
2--------------------------------3-------------------2
3--------------------------------2-------------------3
7--------------------------------7-------------------5
4 and 5 bridged
6,8,20 bridged
PC software settings
Handshake Method = Xon Xoff
Baud Rate = 4800 (Starting Point)
Data Bits = 7
Stop Bits = 2
Parity Bit = Even
Old 03-05-2011, 11:27 PM
Many thank's Mr. Bill,it is very useful
good luck!
regards
Rizal
Fanuc 10M - Drip Feed Swemill Fanuc 34 05-17-2011 07:37 PM
Need Help!- FANUC 3M DREP FEED renato13 Fanuc 7 11-24-2010 10:15 PM
fanuc o-t feed rate help joe1970 G-Code Programing 17 08-29-2009 11:49 AM
Fanuc 6MB feed with no spindle rpm???? mt92 Fanuc 13 01-03-2009 10:44 AM
Need Help!- Fanuc 6mb drip feed cowleym General Metal Working Machines 0 03-18-2008 05:25 PM
