Old 03-03-2011, 04:02 PM
vlado is on a distinguished road
Fanuc 0M-B spindle orintation parameter
I have a V.Center with Fanuc 0M-B control. I will replace additional pulscoder on spindle.
Is there parameter for "orientation stop position shift amount" ?
Old 03-03-2011, 04:41 PM
cncserveng is on a distinguished road
This might help (not shouting, just copied text)
SPINDLE ORIENT POSITION SETTING.
THE KEY MUST BE CENTERED TO TOOL CHANGE ARM WHEN THE ARM IS AT THE ENGAGE POSITION, LOOK UNDER SPINDLE.
ANY ERRORS MUST BE ADJUSTED BY CHANGING THE VALUE IN PARAMETER 6531 (4096 = 360 deg.) i.e. 1deg = 11.38 approx.
Old 03-03-2011, 07:45 PM
stevo1 is on a distinguished road
I think you just felt like shouting. I already did tonight on my way home from work in the car. Makes you feel much better.
Stevo
Old 03-03-2011, 11:21 PM
Fanuc 0M-D control used parameter 6531.
I have Fanuc 0M-B control.
Spindle Orintation Problem Greg 24 Haas Mills 10 10-01-2009 11:26 AM
fanuc OM-D spindle orientation parameter? meadowtech Fanuc 2 02-09-2009 11:15 AM
Need parameter for the spindle RPM. g-codeguy Fanuc 2 09-29-2008 07:40 AM
How to setting fanuc serial spindle parameter? ning Fanuc 1 10-30-2005 02:38 PM
spindle orintation fanuc 21iT fjd Fanuc 1 03-09-2005 06:05 PM
