Old 03-03-2011, 05:54 AM
cncchewer is on a distinguished road
Fanuc PMC ladder example - Sub53 AXCTL
I'm in need of another example or better explanation of the ladder programming manual. I read the maual just fine but can't get it to work so I need to see one example. No of my archive ladders are using it so I have nothing to build on.
Specifically the Sub53 AXCTL on a SB7. I am trying to home out the indexers and move X axis while rotating the pallet changer.
I understand the different signals to use - the 4th axis here:
o ECLRB , G154.6 = 1 to reset clear
o EBUFB, G154.7=, axis control command read signal
o EAX4, G136.3, PMC control of A axis
o EC4, G155.3=1, A axis control command
o EID08b, G158.0, 2nd ref return
o EDENB, F133.3=1 while moving from PMC
o ZP24, F96.3=1, when A is at 2nd ref
but not how to incorporate them in to the AXCTL command.
Any thoughts,
Burke
Old 03-03-2011, 07:43 AM
cnc2149 is on a distinguished road
See attachment file for info on AXCTL function.
File Type: pdf Application Note - PMC Axis Control.pdf‎ (404.4 KB, 296 views)
Old 03-03-2011, 07:54 AM
thanks CNC2149
Thanks 2149 for the quick reply. Nice document. I will try to digest a little later and get back to you.
Tags
axctl, axis command, fanuc, pmc, sub 53
fanuc om-a ladder rathi_vk Fanuc 2 06-11-2009 09:34 PM
ladder fanuc om-a rathi_vk Machine Problems, Solutions , Wireless DNC, serial port 1 01-11-2009 01:34 PM
New Machine Build- FANUC LADDER CHAD LAWSON Fanuc 7 12-08-2008 12:47 PM
How to use Fanuc Ladder III on OM Namnp2007 Fanuc 2 08-05-2008 11:08 PM
Fanuc ladder guhl Fanuc 3 12-07-2007 12:54 PM
