Old 02-25-2011, 09:49 AM
keyancnc is on a distinguished road
fanuc O-TD character extension function
Dear friends,
how to enable the character extension soft key (C-EXT) in fanuc O-TD controller. because i cant able to find the C-EXT soft key in edit screen. so i want to type the title blocks to my program.
Regards,
keyan
Old 02-25-2011, 12:20 PM
cnc2149 is on a distinguished road
The 0i-D Parameter manual only lists the following parameter to enable you to enter parenthesis when you have the small MDI keyboard:
3204 bit 0 PAR
When a small MDI unit is used, characters "[" and "]" are:
0: Used as "[" and "]".
1: Used as "(" and ")".
Old 02-26-2011, 05:44 AM
dcoupar's Avatar
3204 bit 0 PAR
And on the 0i-C, 3204 bit 2 EXK enables the C-EXT function. But keyan said he has a 0T-D, not a 0i-series. I can't find any reference to the C-EXT function in the 0T-C or 0T-D parameter manuals. I'm thinking this wasn't available on the 0T-C or D models.
Old 02-26-2011, 06:08 AM
I misread your control type. I do not know of a method of entering parenthesis with a 0-TD. Brute force method of entering parenthesis is to output the part program to a computer, edit in the parens, and transfer it back to the CNC.
Need Help!- Adding an M function on a Fanuc 11M jjproto Fanuc 4 11-18-2010 12:12 PM
Fanuc 18i Position switch function chiz Fanuc 5 09-30-2010 02:15 PM
Need Help!- Fanuc OM no tape or dnc function cadcamsa Fanuc 8 04-30-2009 04:07 AM
Turn on DNC Function / Fanuc 0MC emcomannen Fanuc 6 06-19-2008 08:47 AM
Fanuc 11M M function problems 9566317 Fanuc 6 03-16-2006 08:30 PM
