Hello Not sure if anyone can help ?, I need the parameter list for a Hitachi Seiki 3NE 300 lathe , It seems some of the parameters have changed and the lathe is doing odd things! ie speeds entered are not displayed as entered and spindle runs at full speed, but at start up with no speed entered spindle runs and jog run at low speed ??? Tool Changer index's to correct tool number but displays a 4 digit number not tool number that was selected ? Thanks |
With regards to the tool number display, where is this being displayed? If in the long, segment LED display then 4 digit is correct; 2 digits for the tool number and 2 for the offset. If in a separate display, then this would be an OEM provided feature and is probably not parameter related. I can provide you with a Generic set of parameters, but not from an Hitachi Seiki. It won't be for a few days though, I'll have to go to a client's works that has this control. Please let me know if you want this Generic set, so as not to waste time. Regards, Bill |
| Hello Bill Thanks for your reply , I will be spending some time on the lathe tomorrow and will get a few more details and contact you again so no need to go out of you way at the moment , the digits appear on the bottom row and were showing tool number also if I enter a speed it is no longer shown in RPM and spindle runs at max RPM no matter how high or low you set speed and after pressing C old value returns if you press enter. Machine was working fine and after dinner break thing had gone a bit mad!. M08 and M09 displaying as 80-81 Regards Chris. PS If I get it sorted would you like to know the problem. |
We always like to know the solution to the problem. If it is not for ourselves then it will help someone else that may stumble across this thread with a similar problem. Stevo |
Just let me know if you need the parameters. Regards, Bill |
| As stated in my first post, I can supply you a copy of a generic 5T parameter list, but it won't be from a Hitachi Seiki. Regard, Bill |
| Regards Chris |
#10
Yes, the parameter list will have an explanation as to the meaning of the parameter settings. You can't change the characteristics of a 5T control from a program, apart from those parameters that are associated with various cycles. With regards to CSS, there is nothing that can be included in a program that will turn it off permanently, if that's what you mean. Its turned on by programming G96 with an S command representing the desired surface speed in either meters or feet per minute, depending on whether the machine is in metric or imperial mode, G21, G20 respectively. Check that your program has the G96 code included. Regards, Bill |
| Hitachi Seiki w/ Fanuc 18 C | jumpstart | General Metal Working Machines | 0 | 03-16-2010 03:20 PM |
| Need Help!- Hitachi Seiki 4NE-600 parameters | padams | Fanuc | 1 | 06-23-2009 08:22 AM |
| Need Help!- Hitachi Seiki Fanuc 11M Parameters | diegojulio | Vertical Mill, Lathe Project Log | 0 | 03-02-2009 05:33 PM |
| Need Help!- HITACHI SEIKI / Fanuc 11m | mn12mike | Fanuc | 2 | 12-14-2008 11:06 AM |
| HITACHI SEIKI 25S/FANUC 10T PROBLEMS | conceptmachine | Fanuc | 3 | 04-21-2008 08:29 AM |
