Old 02-13-2011, 05:55 AM
Master Miller is on a distinguished road
Fanuc G54.1
Hello,
Can someone explain me how the aditional zero point works with Fanuc?
Example: G54.1 to G54.48 (I believe there are 48 points??)
I wanna know: How I program this en how I call them.
(sorry for my bad english)
Thnx for helping!
Grtz from the Netherlands
Old 02-13-2011, 06:00 AM
beege's Avatar
beege is on a distinguished road
G54.1 works just like G54, G55....G59. It's only G54.1 though, and P1 though P49
If you have it turned on, you have a table added to you work coordinate systems for P1, P2, P3 etc.
G54.1 P1 X0 Y0
(stuff happens)
G54.1 P2 X0 Y0
(more stuff happens, different place)
Hope it helps!
Beege
Old 02-13-2011, 06:33 AM
thnx for your reply!
But how does my program look?
En how I define it?
En are the coordinates data from the ref. point? Like a normal G54?
Hope you will help me
Thnx
Old 02-13-2011, 06:53 AM
angelw is on a distinguished road
En how I define it?
Thnx
Offset values for G54.1 P1 through P48, or alternatively up to 300, are set in the same way as G54 to G59. A P value should be specified after a G54.1, if its omitted P1 is assumed. G54.1 is called in your program in the same way G54 to G59 are. For example:
G90 G00 G54.1 P1 X0.0 Y0.0
Regards,
Bill
Old 02-13-2011, 07:14 AM
Regards,
Bill
Thnx, I think i understand,
except one thing:
How and where i define for example P1???????
Thnx!
Old 02-13-2011, 07:29 AM
except one thing:
Thnx!
If your control has the additional Offset System, the registry can be accessed via the OFFSET function keys, or input via program using G10; the syntax for this is:
G10L20 Pn IP
Where n is the offset number and IP is the axis address and value. These values can be applied in absolute or incrementally by specifying G90 or G91 respectively.
Regards,
Bill
the latter is
Old 02-13-2011, 07:37 AM
G10L20 Pn IP
Regards,
Bill
the latter is
Oke, for example, is this correct?
G10 L20 P1 x.. y.. z..
G54.1 P1
G90 G0 x.. y..
En what does L20 mean?
Grtzz
Old 02-13-2011, 07:50 AM
G54.1 P1
G90 G0 x.. y..
Grtzz
Yes, that's correct. L20 specifies that its the additional offset system that's being accessed. When specifying the additional offset system, it can be programmed as just G54 Pn. It has the same meaning as G54.1 Pn.
Regards,
Bill
Old 02-13-2011, 08:03 AM
Regards,
Bill
Oke I gonna try it.
But is it also possible to write G54 via the program?
Like:
G10 G54 x.. y.. z..
G54
G90 G0 x.. y..
Hope you understand what i mean.
Grt
Old 02-13-2011, 08:21 AM
Oke I gonna try it.
Like:
G10 G54 x.. y.. z..
G54
G90 G0 x.. y..
Grt
Just to differentiate between the two systems I would use G54.1, but G54 can be used as long as the Pn is specified.
With regards to your question relating to G10 G54 X...Y...Z..., the answer is no. You have to specify L20 for the additional offset system.
To set the standard offset system G54 through G59 via G10 the syntax is as follows:
G10 L2 P1 X... etc (G54)
G10 L2 P2 (G55)
G10 L2 P3 (G56)
G10 L2 P4 (G57)
G10 L2 P5 (G58)
G10 L2 P6 (G59)
Regards,
Bill
  #11   Ban this user!
Old 02-13-2011, 08:28 AM
Thank you very much for your answers!
I gonna try it
Grtz !
  #12   Ban this user!
Old 02-13-2011, 11:45 PM
sinha_nsit is on a distinguished road
Everything is nicely explained. I can add just one thing:
G10 L2 P0 X_ Y_ Z_ refers to External WCS.
And, as a matter of personal choice, I recommend the use of system variables (if available) instead of G10 for such purposes.
GE Fanuc & FANUC proprietary posts CNCadmin Fanuc 44 01-05-2012 08:54 AM
Need Help!- Difference between Fanuc 0i-MC and Fanuc 0i-MD humak16 Fanuc 12 12-29-2011 10:49 PM
can fanuc ac digital servo amplifiers be run by a controller other than fanuc? js412000 Servo Motors and Drives 5 03-09-2011 09:11 AM
Fanuc & GE Fanuc Repairs RRL Product Announcements & Manufacturer News 0 10-01-2008 12:42 PM
