Old 02-12-2011, 02:49 PM
Scottjit is on a distinguished road
Exclamation PCMCIA Slot
I have a Fanuc Mill with a 16M on it. The card reader PCMCIA slot next to the screen stopped working. I have check all the cables. The RS232 still works. Is this a hardware problem and which board is it?
Old 02-12-2011, 03:12 PM
cnc2149 is on a distinguished road
This is not an uncommon problem and most of the time it is a failure in the "PCMCIA Cable", as FANUC refers to it. This assembly consists of the PCMCIA socket, the short length of mylar cable and then a connector at the other end. Even if you don't have visible bent/broken socket pins, it can sometimes develop an internal connection failure. Replacing this PCMCIA Cable usually corrects the problem.
There are 4 different PN so you need to get the correct one. The newer controls have the PN marked on the concealed side of the cable. The older ones do not have the PN listed. If you unplug it and cannot see the PN, call FANUC and they should be able to identify the PN and sell you the replacement part. It would help to have the CNC Serial No. or the high level A02B-xxxx-xxxx PN of the display unit when you contact them so they can break it down.
Tags
card slot, pcmcia
cutting a slot with a t-slot cutter cncuser1 Mastercam 11 09-09-2008 09:02 PM
PCMCIA slot with a wireless card cflues Fanuc 5 12-06-2007 10:05 AM
Coated Carbide 4Flute Endmill, 3Flute Slot Drill, or 2Flute Slot Drill? weaston General Metalwork Discussion 7 04-11-2007 09:00 PM
