Old 02-10-2011, 09:51 AM
trent2 is on a distinguished road
fanuc Oi- MC control
Looking for help concerning man reables on this control. Can only get them when load off a card with them already in the perogram. can not find and () brackets only squ brackets. Would like to know if any has found a way to enter man reables or to modify exsisting ones.
Old 02-10-2011, 10:31 AM
sinha_nsit is on a distinguished road
The same key gives ( or [ depending on a parameter.
If it is set for [, you can have ( through a soft key C-EXT.
Old 02-10-2011, 11:26 AM
cnc2149 is on a distinguished road
Here is additional information to the reply from sinha_nsit:
Parenthesis on small keyboard
3204.0 (PAR) When a small keyboard is used, characters "[" and "]" are:
0 : Used as "[" and "]".
1 : Used as "(" and ")"
3204.2 (EXK) During program editing in the EDIT mode, character input with soft key [C-EXT] is:
0 : Performed. ([C-EXT] soft key is displayed.)
1 : Not performed.
NOTE:
The [C-EXT] soft key is used to select an operation on the program screen.
This soft key enables the entry of "(", ")", and "@" using soft keys. This soft
key is useful when using the small MDI keyboard, which does not have
the "(", ")", and "@" keys.
Old 02-10-2011, 07:04 PM
Thanks soft key worked great
Old 02-10-2011, 08:08 PM
canwong is on a distinguished road
Yes, just set the parameter right, then you can do that.
Regards.
www.gskcnc.cn
Need Help!- Fanuc O-T control Antonio Arguijo Fanuc 4 12-04-2010 01:43 AM
Need Help!- Velocity Control Drives and Fanuc 2000C control redialtone Fanuc 3 06-21-2010 09:26 PM
G13 on Fanuc 0i control davisboys Fanuc 4 09-01-2008 08:25 AM
Need Help!- fanuc control ezavarse General CNC (Mill and Lathe) Control Software (NC) 2 02-22-2008 06:31 AM
Fanuc 18T control m_ghaff2000 Fanuc 1 09-26-2006 07:05 AM
