I'm not sure if this is the right place to ask this question, but on a Fanuc control what does the 0V side do, it's usually tied in with the 24V. I have been having problems with a turret count proximity switch on a Citizens F-16. With the 0v wire disconnected (also has 24V and output wire) I get a signal from the switch, and with it connected I get nothing. Either way it doesn't react to the cam that moves past it to create the count signal. I had another switch in there that was working, but intermittenly the machine would stop and I had to write the turret position in MDI or it wouldn't sense the right turret count and not engage the shot pin. Any ideas? Thanks |
| 0V is the 24vdc common, if you have a 3 wire proximity switch, then it requires both 24v and common (0v) as well as the signal wire to operate properly. If you have it connected correctly and it does not read a metal flag in front of it, then it sounds as though it is defective? Al.
| Most Fanuc control inputs supply the load required for most prox. Al.
| Mitsubishi wire type setting for zinc coated wire | Futurewire | EDM Machines | 1 | 01-26-2011 03:47 AM |
| Mitsubishi wire type setting for zinc coated wire | Futurewire | EDM Machines | 2 | 01-25-2011 06:49 AM |
| Running stepper motor wire with router wire? | basskitcase | DIY-CNC Router Table Machines | 2 | 02-19-2010 10:18 AM |
| Wire EDM - Wire Type and Size | greenchair | General Metal Working Machines | 0 | 06-17-2009 01:44 PM |
| power supply size? for multi wire (total 250 inches of wire) | DanOSB | CNC Wire Foam Cutter Machines | 5 | 03-02-2009 04:34 PM |
