Old 02-07-2011, 12:58 PM
kningzer is on a distinguished road
Is it possible to turn an axis into a spindle
Hi everyone.
I have a little programming problem. The machine is a grinder (think od grinder).
Im going to make a od grinding where im using A axis and The Y axis.
The problem is that i want to be able to spin the A axis at a set rpm or feed but i want to have another feed for the Y axis.
So is there any way to use the A axis as a spindle? I have seen this on other machines but how do i do it in a Fanuc?
The controller for the machine is a Fanuc 15M
Hoping for help. Thanks in advance
Need Help!- how to turn on spindle while mill spindle is on!! the mill kid Mazak, Mitsubishi, Mazatrol 3 11-22-2010 01:08 PM
Spindle won't turn on ranchak Bridgeport and Hardinge Mills 5 08-29-2009 06:32 PM
Please help! Z-axis transistor keeps failing when I turn spindle on jderou Bridgeport and Hardinge Mills 1 03-27-2009 07:09 AM
interact 4 spindle drive won't turn on spindle 0041601 Bridgeport and Hardinge Mills 7 06-23-2008 05:51 PM
Ver 7.0 Eztrak 2 axis. Spindle wont turn MrMudd Bridgeport and Hardinge Mills 3 06-13-2006 01:18 PM
