The result is some displacement in slide position. I want to know a typical order of magnitude of this displacement. Specifically, how many pulses are typically needed for least slide movement in IS-C (i.e., 0.0001 mm / 0.00001 inch)? 1, 10, 100 or something else? Al the man is requested to respond, since most of us do not understand the behavior of the control at hardware-design level. |
| No answer yet. I have heard that one pulse typically causes a rotation of 1.8 degree in stepper motor. That is, 200 pulses for a complete rotation. If gear ratio is R, and pitch of the lead screw is 10 mm, this will cause a displacement of 10/(200R) per pulse, which is equal to 0.05/R mm. To ensure an accuracy of 0.001 mm, R should be minimum 50. On a servo, similar thing might be happening. How accurate is my information? I would appreciate correct / more detailed information. |
| Your self answer is correct on a stepper the smallest increment is based on the mechanical resolution at 1.8° degree movement of the stepper. On a servo it is based on the resolution of one encoder pulse count after any x4 increase in pulse resolution. Al.
| For Fanuc they go from 2000 ~2500 x4 to the serial Hi-res type that are 300,000 pulses/rev. Al.
| Thanks again for the information. I was expecting that total number of pulses associated with one revolution must be in thousands. You gave a typical value of 300000. I guess steppers also might have become more accurate than just 200 pulses/rev. What is the typical max value these days? |
| It depends, if you use built-in electronic gearings in the servo systems, you can reduce the no. of steps for one rotation
__________________ http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/ http://my-diysolarwind.blogspot.com/ |
| I got the following information (http://www.omega.com/prodinfo/stepper_motors.html): "Microstepping is a relatively new stepper motor technology that controls the current in the motor winding to a degree that further subdivides the number of positions between poles. Omegamation microstepping drives are capable of dividing a full step (1.8º) into 256 microsteps, resulting in 51,200 steps per revolution (.007º/step). Microstepping is typically used in applications that require accurate positioning and smoother motion over a wide range of speeds. Like the half-step mode, microstepping provides approximately 30% less torque than full-step mode". But, I have also read that reducing step angle deteriorates repeatibility. |
| Asking G-code into stepper pulse??? | geethat | Controller & Computer Solutions | 0 | 09-03-2010 11:20 AM |
| Need Help!- Adjusting Servo with pulse coder | Dustin L | Servo Motors and Drives | 1 | 12-17-2008 01:13 PM |
| Need Help!- Config for using single pulse for index and speed | rfrenzl | LinuxCNC (formerly EMC2) | 11 | 09-08-2008 05:49 PM |
| stepper setup, Electrical noise ? | veteq | Stepper Motors and Drives | 3 | 02-07-2007 10:31 PM |
| Right pulse for stepper | cncbox | Stepper Motors and Drives | 4 | 08-16-2005 12:18 AM |
