| Guy's, How can I switch gears in a program? I am using a 1.5 turbo mill at 1200RPM (high gear), and then tapping later at 200RPM(low gear). Unless I manualy put it in handle, then hit the switch gears button it defauls to the lowest speed in high gear, which will not give me the correct spindle speed and booger my threads. I have a high/Med/Low gear. Thanks, |
| M41 1st gear "Low Gear" M42 2nd gear "Med Gear" M43 3rd gear "High Gear" Try one of those if the spindle is not auto adjusting to the rpms that you program. If that does not work the spindle gear change M codes range from M40 to M45 Last edited by Perfect Circle; 02-03-2011 at 11:32 AM. Reason: Add more info |
| Perfect Circle, Tried it. Didnt work. Just defaults to the low or high gear that I am in. Maybe I am not typing it in the program correct or I need to add something to make it change like a G05 or something? Got any ideas? |
| Thanks, Joe. |
I have an H-12 oprator manual with M codes M40 should be nuetral M39 High gear M38 Low gear. I also have full stock on Fanuc 6MB CNC control boards. Service company in New Jersey. Accurate Machine Repair.com |
| H15 with Fanuc System 6MB M10 TOOL CLAMP M11 TOOL UNCLAMP M17 ATC TO MAGAZINE SIDE M18 ATC TO SPINDLE SIDE M19 Spindle orientation M22 TOOL LOAD – from magazine into the arm M23 TOOL UNLOAD – from the arm into the magazine M24 TOOL ARM CHANGE M36 NEUTRAL GEAR, spindle free M37 LOW GEAR 0 –437 rpm M38 MIDDLE GEAR 0- 1334 rpm M39 HIGH GEAR 0- 4063 rpm M46 TABLE UP UNCLAMP M47 TABLE DOWN CLAMP M48 CANCEL M49 M49 OVERRIDE CANCEL M50 WORK AIR BLAST M51 CTS COOLANT M55 FORK 1 EXTEND M56 FORK 2 EXTEND M61 PALLET LOAD M62 PALLET UNLOAD M68 PALLET CLAMP M69 PALLET UNCLAMP M90 MIRROR IMAGE CANCEL M91 MIRROR IMAGE X M92 MIRROR IMAGE Y M93 MIRROR IMAGE 4 |
| Mazak QT-8 with a T32B controller need help | Captdave | Mazak, Mitsubishi, Mazatrol | 3 | 02-18-2011 09:18 AM |
| Need Help!- MAZAK HMC with M32 CONTROLLER | rajesh_1355 | Mazak, Mitsubishi, Mazatrol | 2 | 02-18-2011 09:15 AM |
| Need Help!- Connecting DNC OR CMT to a mazak m-32 controller | toolmaker23 | Controller & Computer Solutions | 0 | 03-12-2010 12:32 AM |
| Mazak VTC-41 Controller cards | Aussie_guy00000 | Mazak, Mitsubishi, Mazatrol | 11 | 10-03-2006 11:42 PM |
| Mazak V-10 with Fanuc 7M Controller | Doubleddaved | Fanuc | 11 | 04-05-2006 08:57 PM |
