Old 02-02-2011, 11:58 AM
guhl's Avatar
guhl is on a distinguished road
excessive error, position readings run on Fanuc 0
machine works
Z axis gets stopped
401, 421 alarms appear
meanwhile, on position screen Z axis readings run in "-" direction
and in diagnostic parameter 801 I see position error runs in "+" direction
if I push Estop Z axis readings get stopped, but positin error goes on
if I disconnect encoder, situation is the same, but controller shows "axis disconnect"
Soviet ICs are the largest ICs in the world!!! )))
Old 02-04-2011, 10:14 AM
Stupidav is on a distinguished road
Sounds to me like that axis has physically come to a stop but the Motor and encoder is still running. Have you looked to see if this is the case?
If so depending on the drive; example Ball Screw, the Nut quite possibily is broken or even the screw itself.
Motion Master 5 Axis Router.......Fagor 8055/C.......Surfcam Velocity 4.0 B189
Old 02-08-2011, 06:22 AM
guhl's Avatar
I disconnected encoder, but the case was the same
Old 02-08-2011, 08:41 PM
Aaron liang is on a distinguished road
You can try to modify the prameters of 505.
Aaron
fanuc o-t alarm 1006 tool position error Korellibopper Fanuc 13 11-18-2011 11:48 AM
Arrow 500 Z axis excessive following error Slick27 Cincinnati CNC 2 01-12-2011 04:28 PM
OLD UHU POSITION ERROR dfv UHU Servo Controllers 2 03-22-2010 12:16 PM
K2 CNC position error - please help ! Geetar-ist K2CNC 5 09-13-2009 04:24 PM
AL-02 Excessive speed deviation Fanuc machinist360 Tree 7 08-04-2008 09:07 PM
