Old 02-01-2011, 06:49 AM
QUALMACH1 is on a distinguished road
Exclamation Helical Mill
Guys,
I have a Mazak H-15 with a fanuc 6m series 901 version 13 controller. I need to know how to do a helical mill. Here is the code I am using...
G03 X0 Y2.75 I0 J-2.75 Z-4.5 Q.1 F1.5 M3 S1200; This gets me into position, but when it starts it does not step .100" per revelution (Q.1), it go's full Z depth in 1 revelution. I am using a 1.5" inserted cutter, and only want it going in Z .100" per rev untill it reaches full Z depth. Thanks,
Old 02-01-2011, 08:40 AM
dcoupar's Avatar
There is no Q mentioned in the 6M-B manual. You can program a sub call with a repeat count (L).
G00 X0 Y2.75 Z0.1
G01 Z0 F1.5
M98 P101 L45
G00 G90 Z0.1
M30
O101 (HELICAL SUB)
G91 G03 I0 J-2.75
M99
Old 02-01-2011, 08:42 AM
sld4121 is on a distinguished road
Since it is a fanuc controlled machine, helical milling will not step down. You have to program pass by pass or use a macro. I believe starting with the 18i and above you can do it with an option called spiral/conical interpolation. However, since that was around $1750, most people continue to use macros.
Old 02-01-2011, 08:59 AM
G00 X0 Y2.75 Z0.1
G01 Z0 F1.5
M98 P101 L45
G00 G90 Z0.1
M30
O101 (HELICAL SUB)
G91 G03 I0 J-2.75
M99
I never have used subs..not sure how to do this, but say I call out program O0001 write the program as above, then do I write another program for the sub say O0002? Or will the P tell it to look for the sub in this program O001? Thanks,
Old 02-01-2011, 09:03 AM
As you correctly assumed, the sub program needs to be separate from the main program. Just remember to end with a M99 so it knows to return to the main program when it is done.
Old 02-01-2011, 09:51 AM
worked great except for this, when it finishes the G03 it go's up in Y...thats not a good thing. Here is what im doing. I have a part that is 4.5" thick, it has na hole burned in it that is 6.875" in dia. I am milling it out to 7" using a 1.5" inserted cutter, thenim gonna finish bore it to size. The program is starting Y2.5, then it G03's back to Y2.5, then for some reason it starts feeding on up in Y. Why is this...how do I get it to stop at Y2.5?
Program so far...
O1570;
G40G80G90;
G54;
M08;
M3S1200;
G0X0Y2.75;
G0Z.1;
G1Z0F1.5;
M98P0001L45;
G0G90Z.1Y0;
M05;
M09;
M00;
(HELICAL SUB)
O0001;
G91G03I0J-2.75F10.;
M99;
Any suggestions??
Old 02-01-2011, 10:04 AM
dcoupar's Avatar
Program so far...
O1570;
G40G80G90;
G54;
M08;
M3S1200;
G0X0Y2.75;
G0Z.1;
G1Z0F1.5;
M98P0001L45;
G0G90Z.1Y0;
M05;
M09;
M00;
(HELICAL SUB)
O0001;
G91G03I0J-2.75F10.;
M99;
Any suggestions??
I don't see how the program could stop at Y2.5 when the 6th block positions to Y2.75, and the G03 helix ends at Y2.75. Please re-check the program.
Old 02-01-2011, 10:42 AM
Looks like your helical sub is missing a negative Z value.
Otherwise, it should only be able to go to Y0 at the end of the 45 loops.
If it still does not work, try the following,
(HELICAL SUB)
O0001;
G91G03X0Y-2.75Z-.05I0J-2.75F10.;
Y2.75Z-.05J2.75;
M99;
This should just break the arcs into segments
Old 02-01-2011, 11:06 AM
dcoupar's Avatar
Oops... my bad.
(HELICAL SUB)
O0001;
G91 G03 I0 J-2.75 Z-0.1 F10.;
M99;
Old 02-01-2011, 11:50 AM
Yea...my bad, I had it programmed to go y2.5 in the sub program i forgot it was in G91...It now has a Z-, and it working great!!!! Thanks, guys. This machine had not been used at all hardly in our shop, due to no one knowing how to correctly program it. we are now using it daily thanks to you good pepole! Godbless you ALL!
  #11   Ban this user!
Old 02-01-2011, 02:23 PM
dcoupar's Avatar
Glad we could help. Good luck.
Need Help!- Radial Helical Mill with Live Tool Puma 700LM bdyenter Daewoo/Doosan 2 01-22-2010 12:35 AM
Helical interpolate vs. drill then open with mill Brian FRF General Metal Working Machines 1 08-07-2009 02:27 PM
Need help lathe on a mill helical or not bigtoad170 General Metalwork Discussion 5 07-30-2008 12:09 PM
Fanuc 6mb do I need a BTR?? Also it wont helical mill ? mt92 Fanuc 3 10-18-2006 10:25 PM
Fagor 8055 Mill Sample Code and Helical Interpolation sailcam G-Code Programing 3 10-12-2006 06:37 AM
