Old 01-27-2011, 07:48 AM
inflateable is on a distinguished road
tool length value parameter - which is it?
Hi All,
I'm a bit rusty at parametric code, and i'm struggling a bit on something basic.
I want to let my code see the length of the tool that is is the spindle, but I can't remember the parameter number.
I was sure it was #200x, where 'X' is the tool number, but that's just returning the tool number. Anyone help?
To clarify -
Tool 9 has a lenght offset of 150.00mm in the offset table.
I run
#1=#2009
I'd expect #1 to then be 150.0, but it's not - it's 9
Anyone know? This is on a DahLih VMC
Old 01-27-2011, 08:25 AM
angelw is on a distinguished road
Originally Posted by inflateable View Post
Hi All,
To clarify -
I run
#1=#2009
1. If the machine uses tool compensation memory A, then it will be #2000 + the tool number, eg. T09 = #2009
2. If the machine uses tool compensation memory B or C, then it will be #2200 + the tool number, eg. T09 = #2209
4. Use #4120 to get the spindle tool number.
Regards,
Bill
Old 01-27-2011, 08:28 AM
yup...
...thanks bill - not a type A, which threw me.
Sorted!
Need Help!- set up tool length offset and ref tool on mill buklattt CNC Machining Centers 2 04-01-2012 11:01 AM
Tool Tip Length eliot15 General Metalwork Discussion 4 11-13-2010 07:07 PM
Need help with tool length offset panaceabea Haas Mills 32 03-04-2009 01:07 PM
G43.1 - Tool Axis Direction Tool Length Compensatioin EngTech Mazak, Mitsubishi, Mazatrol 8 12-06-2007 04:01 AM
