Old 01-26-2011, 10:11 AM
kirby is on a distinguished road
Fanuc OM stuck in MDI mode
We were running a program and out of the blue the machine shut down and went to MDI mode.... Turning the mode selector does nothing. Cant get the machine to move. Tried entering a program in MDI which i can do. Went to send it home but i had powered the machine down and its first move was rapid down. Now the cutter is 2 " from the table and i dont have a clue what to try next.
Need help....i have jobs that are backing up now...
Old 01-26-2011, 10:45 AM
underthetire is on a distinguished road
Usually stuck in MDI means you lost a power supply, or something is emergency stop. The Z probably fell due to the brake releasing, not actually being driven down.
Old 01-26-2011, 10:55 AM
It did seem to fall with a greater speed that i was expecting since rapid over ride was turned way down..
In the process of checking for a blown fuse somewhere..
Old 01-26-2011, 11:12 AM
WillieDo is on a distinguished road
Try to MID G-28 X0 Y0 Z0,and send it home slowly... when you at home reset your program to G01 or slow down on your rapic to 50% or 25%.if this work ,you should change your G00 from the begin of the program to F 50 ...you may get the short some where in power supply...check you 24V power supply 80% duw to 24V power supply. this case you Z move servo power supply.
good luck
Old 01-26-2011, 11:31 AM
Can anyone tell me what a W.A. ascent switch is and where I might find it?
Old 01-26-2011, 11:41 AM
good luck
G28 Z0 sent it down at full rapid....i am now down to a Z overtravel and 1 " from the table.. and i nearly crappped myself when it went down..
Old 01-26-2011, 11:43 AM
and it cant be the brake because it didnt move with feed rate turned down to zero...only when i turned it up....but it was definately under rapid because i only moved the feed rate to 10%
Old 01-26-2011, 11:48 AM
the reason i asked about the WA switch is because there is a rely on my back panel door that has a red light on it. From the ladder diagram it is the relay for that switch. I dont know if a red light means anything on the relay but red is never really good
Old 01-26-2011, 11:56 AM
also, any suggestions on how to get the Z axis up of the over travel limits....since the switch is stuck in MDi i cant use the handle and bypass switch... and i would rather not try any more G28 Z0 moves...
Old 01-26-2011, 12:29 PM
dcoupar's Avatar
Can you get at the Z axis ball screw? In the old days... we used to power down the machine and turn the ball screw by hand to raise the head. That was before brakes, though.
It's possible that when you did the G28 Z0 you were in absolute mode. It's usually safer to do G91 G28 Z0.
  #11   Ban this user!
Old 01-26-2011, 12:30 PM
Kirby
G28 Automatic return to reference point, should send your machine home,check your setting swich on Absolute or Incremental, manual bypass over travel by get some one press and hold your Z over travel limits and slowly move the handle on Z out of travel limits if your bypass do not work.
Can You move Home one Axis at the time?how old is your machine? older machine have the swich turn to Absolute or Incremental..? doulble check that...I can tell you more what to do if I know how olad is your machine!
  #12   Ban this user!
Old 01-26-2011, 12:47 PM
Kirby
It wont let me do anything till i clear the alarm and the alarm cant be cleared till i move off the limit switch. I cant move it by handle and i couldnt move it by the handle before it hit the switch... I am going to have to try to move it up by turning the leadscrew...
6M-B controller shut down while running, now stuck in IL mode Heavymg Fanuc 1 06-24-2010 10:13 PM
Need Help!- Fanuc 6MB stuck in jog mode Andy Fritz Fanuc 9 02-26-2010 03:33 PM
Need Help!- GECKO G540 - Stuck in "FAULT" mode.. HELP!?! CNC74 Benchtop Machines 5 02-06-2010 02:37 AM
What is - Torque Mode? Position Mode? Speed/Velocity Mode? sunmix Servo Motors and Drives 25 10-26-2008 03:53 AM
Stuck In Mm On Fanuc 18t, Help! TEVAN Fanuc 5 12-23-2006 10:58 PM
