Old 01-25-2011, 11:32 AM
nracingdev is on a distinguished road
Oi-TC add comments to macro variable table
Hi guys new to the forum. I am a programmer and I sometimes have operators interface with the machine changing values in the macro variable screen (#500+). I have noticed that there are two columns other than the data entry column. I believe the other two are names and comments. Does anyone know how to enter text into those fields? I have not been lucky searching on the net nor reading the operator manual. Thanks Chris!
Old 01-26-2011, 02:41 PM
stevo1 is on a distinguished road
Chris....welcome to the group.
Yes you can label them. I did a quick search thru the Oi manual and I could not confirm the function in your control. On my 15 series control it is done with the SETVN function. So in MDI mode or in the program you would do this
SETVN500[TEXT]
This would put the word “TEXT” in variable 500 in the comment section. If you wanted to set #501 then change the 500 to a 501.
Stevo
FYI you can also lock specific variables in the control via parameter if you have some that you don't want someone to accidently change.
Old 01-26-2011, 02:57 PM
thanks for the reply. I will give that a try. This enters the "text" into the comments section. how do you enter it into the name section? also what parameter locks the values? that would be a very good function to have. thanks again i have been scratching my head on this for a while!
Old 01-26-2011, 04:11 PM
dcoupar's Avatar
I find SETVN in the 15i, 31i, and 0i-TD manuals, but not the 0i-TC manual. Here's the section from the 0i-TD manual.
Name:	Common Variable Names.jpg‎
Old 01-26-2011, 04:15 PM
cnc2149 is on a distinguished road
The SETVN is used in the Series 11/12/15 and 30i series of CNC controls. FANUC allows one to program the NAME field on the Macro page using an optional feature in most controls that is called Pattern Data Input. Actually, with the Series 0i-C this feature is standard so you should be able to use it.
Go to the Pattern Data Input section of the Operators Manual and you'll see an example. Programming it is not as easy as the SETVN, but it should help you out.
Old 01-26-2011, 04:18 PM
Dave,
I was looking in the Oi-mc manual and could not find it either. I would think that if it does have the "Name" section in the variables that you should be able to write to it but who knows until Chris tries it.
I was also looking for the parameters to protect specific variables. In my 15 series it is #7031 is the start of variables to protect and #7032 is the last variable to protect. So if I wanted to protect #500-#520 I would set #7031=500 and #7032=520. I however could not find this variable in the Oi manual.
Chris,
Yes I meant to say "name" not comment.
Stevo
Old 01-26-2011, 04:43 PM
dcoupar's Avatar
Damn I love this place. You learn something new every day.
Thanks CNC1249
Old 01-27-2011, 01:28 PM
no go. Error 113, improper command is the error I receive when trying to use the SETVN command.
Old 01-27-2011, 01:32 PM
That makes sense since the 0i-C does not support the SETVN. You'll need to use the Pattern Data Input feature to set up a macro variable name in this control.
The reason the 0i-D controls support SETVN is because they are a derivative of the 30i series control family. The 0i-C is derived from the 16i series controller and does not allow SETVN commands.
Old 01-27-2011, 02:40 PM
axis india is on a distinguished road
hi guy
can anybody tell how to use mdi dpl i m having one
  #11   Ban this user!
Old 01-27-2011, 02:44 PM
cnc2149,
I got your PM. Yes I missed your post. Thank you for the info. As Dave said “learn something new everyday”.
Stevo
  #12   Ban this user!
Old 01-27-2011, 02:46 PM
dcoupar's Avatar
Originally Posted by axis india View Post
hi guy
Why did you post this here? You should have started a new thread. What's an "mdi dpl"?
Macro variable #1000, how to edit hydrospin01 Hyundai Kia machine 0 01-03-2011 08:22 AM
macro b local variable samu Fanuc 4 12-18-2010 05:55 PM
Macro Variable Lock James L Haas Mills 2 07-23-2009 08:29 AM
Need Help!- How do I read the value of an F-type parameter into a macro variable? Jan d. Mazak, Mitsubishi, Mazatrol 24 02-17-2009 10:47 PM
Macro variable example I programmed today. theemudracer G-Code Programing 1 03-07-2007 08:50 PM
