Old 01-22-2011, 03:12 PM
dc123 is on a distinguished road
Setting baud rate to 9600 on Fanuc OT
I need to know how to set the baud rate to 9600 on my wasino lathe that has a fanuc OT controler. I need step by step instructions as I am not good at the computer part. Thanks Dennis
Old 01-22-2011, 05:24 PM
angelw is on a distinguished road
1. Set the Mode switch to MDI
2. Push PARAM/DGNOS button
3. Push a PAGE button to display the PARAMETER (SETTING 2) page.
4. Press the cursor button to set the cursor to PWE
5. Key in 1, INPUT, and parameters are able to be modified. P/S alarm No 100 will be displayed. This is normal.
6. Press PARAM button to display parameters on the CRT screen.
7. Shift the cursor to the parameter number to be changed. The parameter for Baud Rate when the I/O setting parameter on the Setting Page is set to 0, is No 552. There are two methods to position the cursor at the required parameter.
i. Depress the CURSOR button. If this button is depressed continuously, the cursor shifts sequentially. Successive parameter pages are displayed as the cursor exceeds the last cursor of a page.
ii. Press the button that is labeled [No. JQP], key in the parameter number and press INPUT.
8. For a Baud Rate of 9600, key in 11 and press INPUT.
9. After the parameter has been set, turn the screen to the PARAMETER (SETTING 2) page, and return the PWE setting to 0 by keying 0 then INPUT.
10. Press RESET to clear the alarm that occurred when PWE was first set to 1.
Regards,
Bill
What RS232 baud rate do you use? and why? gar Haas Mills 68 03-08-2011 09:32 AM
Need Help!- Setting baud rate on Matsuura 560v MadMan5000 Machine Problems, Solutions , Wireless DNC, serial port 4 05-16-2010 12:33 AM
Need Help!- Baud Rate for Fanuc System 6T yumuri Fanuc 5 01-14-2010 01:11 PM
Problem- V-22 baud rate qualitytool BobCad-Cam 0 10-20-2008 08:11 AM
Fanuc O-T baud rate ttorqueshop Daewoo/Doosan 6 12-13-2007 12:57 AM
