Old 01-21-2011, 01:00 AM
machinationus is on a distinguished road
wanted a schematic of the board A16B-1010-0150
will to paypal
i need a schematic of the board A16B-1010-0150 for the RS-232 related
electronics parts ALL. board back number: A320-1010-T156/03 H468
I now have 2 of these boards semi-working, but no means of repair.
at this point repairs are around 4K which is more than newer faster
control.
I have all negative voltage on the rs-232 DB25 pin outs...UART replaced,MC1488-89 and LS157 all replaced, no change.
It shows the 086 alarm within 0.5 sec. on Input or Output
its not the PC or Cables.
This is on 1986 leadwell 0MA control.
appreciate any help
Old 01-21-2011, 09:19 AM
cnc2149 is on a distinguished road
You won't need a schematic. I've never seen a problem with the USART but many problems with the drivers/receivers getting damaged. Replacing the 75188 and 75189 chips on the board should correct the problem. They are located very near the M5 and M74 Honda connectors on the board. Suggest replacing the bad chips with sockets so they can be replaced easier next time.
Old 01-21-2011, 09:28 PM
solution found
Yes they have been replaced, in fact 3 times with new ones. They had the sockets lucky for me. The 8251A uart also replace with zif socket and new chip(s). The USART was OK... The sn75188-89's also OK.
I been working on this thing for months. And call it quits, selling it.
Other than that it works real good. But needs a paint job real bad.
I got a small .avi (55mb) its 30 sec. maybe i'll try utube.
Has 48K memory, Drip feeding was working before the rs-232 blew up.
Old 01-21-2011, 11:42 PM
greenery_fr is on a distinguished road
Hi
Originally Posted by machinationus View Post
will to paypal
control.
appreciate any help
Your PCB had M74 or not if your PCB had M74 you can change to this port for DNC
Regards
Old 01-22-2011, 04:53 PM
Regards
No can not find the M74 only a M27 plug is alone
Old 01-24-2011, 07:52 AM
memoryman is on a distinguished road
I have the diagrams. M5 is the rs233 connector. The chips to replace are 75189 and 75188, locations B22 and B24 respectively.
We have them, but you can buy them at Mouser and Digikey.
Need Help!- Need a new A16B-1200-0800/09B board aerosim Fanuc 0 04-15-2010 10:33 PM
DRIP FEEDING OM-A ..A16B-1010-0210 gabedrummin Fanuc 5 06-25-2009 09:21 AM
Need Help!- Fanuc A16B-1200-0800 BOARD ? bbqa01 Servo Motors and Drives 1 04-12-2009 12:37 AM
Schematic for Fanuc A16B-1211-0890-01 Power Unit celsosc Fanuc 0 11-14-2008 06:02 AM
Need Help!- A16B 1010 0040 gglynn81 Fanuc 2 05-17-2008 10:02 PM
