Old 01-17-2011, 08:03 PM
train guy is on a distinguished road
Unhappy 3000c read out shows 10060006
Hello, I am new to cnc machining in general. I purchased a used acroloc mill w/3000c control and in the process of getting some bugs worked out, have caused a parity error. I changed the battery and decided to clean all of the boards from some fuzz and oil film build up. Well,I didn't get the boards in the correct slots ( I know now, should have marked them or done one at a time ) they popped a couple of fuses ( I repaired ) and now won't do anything exept show 10060006 on the read out, and on the L.E.D.s on board 9 (A16B-0190-0061) are showing off at position 0-8-and 13 the rest are on,(I come up with hex. of 8084) . also, pl1 and pl2 are on, as is the run lamp on the cpu.
My maintenance manual is helping but doesn't show the "code". Any help here would be wonderfull. Thank you.
Tags
acroloc, fanuc, mill, milling machine, readout
Fanuc 3000C control problems nlh Fanuc 29 11-27-2011 05:23 AM
Newbie- 3000c parity need address HELP train guy Fanuc 2 10-30-2010 10:30 PM
Fanuc 3000C truobleshoot..... Drake75 Fanuc 2 09-26-2010 06:38 PM
Fanuc 3000c Mal Lashford CNCzone Club House 0 02-08-2010 05:44 PM
3000C ALARM NBRANCHGRIMES Fanuc 2 01-09-2008 09:57 AM
