The rom chip contains the codes that the computer runs..if it is bad it needs to be replaced...the first thing you should check is your 5 Volts power supply..
It needs to be at least 5.2 Volts..if it is too low you can get all kinds of bad messages like the one you have..hope this helps
LinkBack URL
About LinkBacks
