Old 01-07-2011, 12:04 PM
ED209's Avatar
ED209 is on a distinguished road
Fanuc OT RS232 WIRING AT MACHINE ????
I just picked up a 1990 Leadwell LTC-20P with a Fanuc OT control. I had a quick look in the power cabinet and back of control but cannot see where you would connect the cable for a RS232 connection. If someone could point me in the right direction that would be great. Thanks
Old 01-07-2011, 12:33 PM
Al_The_Man's Avatar
There are generally two RS232 sockets on a 0, and location depends on the exact version, if you send me an email add via a P.M. I can send you the Fanuc RS232 manual.
Old 02-24-2011, 08:17 AM
MDU MDU is offline
MDU is on a distinguished road
Guys, I'm having a problem to connect a fanuc series 21i-TB lathe machine to a Pc using RS232 port.
Any help?
Old 02-24-2011, 01:44 PM
dcoupar's Avatar
Any help?
What problem are you having? Are you getting alarms when you try to READ or PUNCH?
Old 02-25-2011, 04:58 AM
MDU MDU is offline
No I'm getting any alarms, its like the connection does not even exist as nothing happens when hitting the read or punch button.
Only when I'm using a memory card then it reads from the memory card.
Old 02-25-2011, 06:00 AM
angelw is on a distinguished road
Given that you are able to read from the memory card, its likely that you have the wrong input/output device set in parameter #0102. Following is the whole configuration and will work if there are no problems with either the control or the PC and PC software.
Regards,
Bill
Set the following parameters at the control.
#0020 = 0
#0100
bit 1 = 0
bit 2 = 0
bit 3 = 1
#0101
bit 0 = 1
bit 3 = 0
bit 7 = 1
#0102 = 0(RS-232C)
#0103 = 11 (9600)(Baud rate)
Cable pin out for Xon Xoff handshaking
Machine End-------------------------------PC End
DB25 Male connector-------------DB25 Female-----DB9 Female Connector
1 (Chassis ground)------------- (Not connected)---- (Not connected)
2-------------------------------------3-------------------2
3-------------------------------------2-------------------3
7-------------------------------------7-------------------5
4 and 5 bridged
6,8, and 20 bridged
Settings for the PC software
Hand shaking method = Xon Xoff (Software handshaking)
Data bits = 7
Stop bits = 2
Parity bit = Even
Baud Rate = 9600
Old 02-26-2011, 10:35 AM
zavateandu is on a distinguished road
hi
i have the same machine in my shop and monday i will make u a photo for the RS232 place where to input u cable.
see u monday.
Old 03-01-2011, 02:47 AM
on my machine the conector is on right side of the operator's panel where the on/off ncpushbuttons stay.
if u do not have it i will take some picture where to put in in nc andwhat cable do u need
Old 03-01-2011, 07:23 AM
MDU MDU is offline
email add
My email address is mdungco@yahoo.com
Old 03-01-2011, 07:31 AM
MDU MDU is offline
Parameter settings
Regards,
Bill
#0020 = 0
#0100
bit 1 = 0
bit 2 = 0
bit 3 = 1
#0101
bit 0 = 1
bit 3 = 0
bit 7 = 1
#0102 = 0(RS-232C)
4 and 5 bridged
6,8, and 20 bridged
Data bits = 7
Stop bits = 2
Parity bit = Even
Baud Rate = 9600
Hi Bill
Thanx for the information u sent me, I can see that it is very much useful.
The only challenges I'm facing now is that I cannot change the machine parameters and I tried to open the RS232 cable casing but I could'nt identify the connections since there are no numbers.
Regards,
Mdu
  #11   Ban this user!
Old 03-01-2011, 09:07 AM
Hi Bill
Regards,
Mdu
Mdu,
Why aren't you able to change the parameters?
Unless the cable has moulded ends, you should be able to open the back shells.
The attached picture is of the pin assignment for a DB9 female connector (PC End) and a DB25 male connector (Machine End).
If you can't open the back shells of the cable connectors for whatever reason, you will be able to identify the cable pin out using a Multi Meter. Get a DB9 male connector that uses soldered pin connectors from an electronics shop and plug it into the female DB9 connector of your cable; this will make using a Multi Meter easier for you. Now using the attached picture as a guide, you will able to determine the cable configuration.
Regards,
Bill
Name:  Comms Cable1.bmp
  #12   Ban this user!
Old 03-01-2011, 11:23 PM
missed
hi
angel u forgot to draw the6,8 and 20 briged.
fanuc 0t rs232 rvila Fanuc 1 04-02-2010 12:02 PM
Need Help!- Rs232 to Fanuc 6TA yumuri Fanuc 1 01-17-2010 09:00 AM
Help with RS232 WIRING DIAGRAM gyazbek Machine Problems, Solutions , Wireless DNC, serial port 9 04-23-2009 06:55 PM
RS232 wiring configuration detection devices Petro Haas Mills 1 04-11-2007 07:27 AM
Rs232 Wiring Diagram? mikeh78 Haas Mills 12 04-09-2006 02:55 PM
