We recently lost power and had a ram parity error so the memory had to be cleared. We got the machine perameters reloaded but do not have the tool change macro. Can anyone help me out with this? Called Toyoda but they have been unresponsive thus far. |
| Some time back I posted a general tool change macro based on what I use on out Toyoda HSP-550's that should work. Sample Fanuc Tool change macro |
| NJ, If you just need something quick to start changing tools then you need to first make sure that the tool change position in the Z is the same as the home position. If that is the case then you can use the G91G28Z0 to get you into position for a tool change. Do you remember what program number your tool change macro was? You should be able to look in the parameters to see which one is set =6. It will be in the parameter range of 7071-7079 or 7080-7089. Let us know and we can go from there. Stevo |
I got in touch with Toyoda and they got me a new macro we are going to input. I did go into the parameters and 7073 was 6, so we are going to change that back to 0 and change 7080 to 6 and enter the following program: % O9020(ATC PROGRAM) (SET PARAMETER #7080=6) #4=#4003 G90G53G30Z0M9 G90G53G30Y0(INSERT -X- POSITION HERE IF NEEDED) M6 G#4 M99 %= |
| There you go. Cool that will work for you. It is really basic and you can many functions if you feel like it. I like to add many things like dpuch was referring to. This is defiantly all you need though. Stevo |
| I just posted an update for the home position issue, and it should solve any problems with using G54 as well. This was something we had changed, but I never looked back at the code posted in that thread. Dale |
| Sample Fanuc Tool change macro | dpuch | G-Code Programing | 6 | 06-01-2011 08:13 PM |
| need help wana make macro for getting tool change by giving tool pot no on vmc instea | ghevari | Parametric Programing | 0 | 02-14-2010 12:26 PM |
| Toyoda FV65 / Fanuc11m Parameters | bluedemon | Fanuc | 3 | 02-03-2010 08:00 PM |
| Fanuc OM tool change macro for a Kiwa/Excel | TR MFG | Fanuc | 5 | 01-27-2008 04:00 AM |
| EDIT O9000 tool change macro fanuc 0M | mikul | Fanuc | 1 | 04-20-2007 06:06 PM |
