Originally Posted by Scottjit We have a V20 0m with a 2 pallet system. The machine works correctly but the pallet has not worked in 5-10 years. We have everything machenical working correctly. It will drop off the pallet and move to pick up the new one Y-31.8897. This is when we get a (2028 x y not in position) alarm for pallet #2. I think there are data bits to tell it where the correct position is but not sure? The first pallet change is at home postions and it works. |
Its highly likely that a Custom Macro program is used to carry out the pallet change, and will be a protected program in the 9000 to 9999 program area.
1. Set bit #4 of parameter #0010 to 0 to enable viewing of these programs.
2. Set bit #5 of parameter #0011 to 1 so that the Macro program can be stepped through in single block.
With the above parameters set, program a pallet change that will result in the error situation, and single block through the Macro program to see what commands are used to position for the pallet change and go from there. Post back if the above is the case and you require further help.
There may be a proximity switch that confirms the "In Position" of the Y slide for the pallet change. You need to determine if there is such a switch anywhere in the area that can be made when the Y slide is in the position for the pallet change. If so, check that its working. If I'm correct about a Custom Macro program being used and that a proximity switch is being used for confirmation, you may see reference to Interface Signal variables, typically #1000 to #1015 and #1100 to #1115.
If the pallet change is not carried out with a Custom Macro program, its control will be via a Ladder Logic program. If this is the case, you should have a copy of that included in the manuals for the machine. You will have to find the area of the program that controls the pallet change in the Ladder and see that the logic is being satisfied.
My bet is that it will be a faulty prox, but time and further investigation will tell.
Regards,
Bill
