I'm finally getting to put together what I have of my Series 16. I also have two other different Opt. 2 boards. Most of these parts I do have, and some I have more than one part. I want to get the most out of my configuration, and plan on configuring it as a "16M". Here is my proposed FS16B configuration: Main CPU Board: A16B-3200-0170/03C Main-A CPU board OPT1 Board: A16B-2200-0919/03A Graphic Board OPT2 Board: A16B-2202-0400 or -0401 Opt. 2 Sub CPU (Not sure which one to use?) PMC A16B-3200-0054/06B Opt. 3 PMC-RC OPT2 Board: A16B-2202-0850/03A FS16B w/ sub CPU Main B + 6 axes Loader Control A16B-2202-0560/04A Loader Control FS16 Main-A spec. I/O Output (Sink) A16B-2200-0954/03A I/O I w/High Speed Skip I/O Output (Sink) A16B-2200-0955 w/A20B-9001-0480/05B Sub-I/O I/O Output (Source) A16B-2202-0720 A16B-2202-0725 A16B-2002-0726 I/O A(64/32) A20B-2200-0660/04A Serial DMA Add on A20B-2200-0010 Graphics A20B-3200-0010 or A20B-3200-0011 (Which one?) A20B-2900-0142 or -0143? Loader Control (Which one- with or without SLC?) A20B-2901-0960 For PMC-PB3/RC3 A20B-2900-0290 or -0291 1MB or 768kB ROM (Which one?) A20B-2900-0311 Graphic Control A20B-2900-0350 Which module is this? A20B-2900-0941 or -0942 2MB or 4MB DRAM A20B-2901-0981 or -0985 Serial Spindle for Main and Opt. 2 boards A20B-2901-0060 What card is this? where does it go? A20B-2902-0080, -0081 or -0082 (Which one?) A20B-2902-0094 6MB FROM 512kB SRAM A20B-2902-0193 or -0197 512kB/512kB or 1MB DRAM (Which one?) A20B-2902-0250/05C PMC RB4/RC4 A20B-2902-0270 or -0278 Graphics for 14" CRT or LCD A16B-2902-0341 FROM 4MB 256kB SRAM A16B-2902-0350 or -0351 256kB or 256kB/512kB (which one is better?) A20B-2000-0640 or -0650 4Slot or 6Slot Backplane? I need to know which will fit all of these components. A13B-0154-B001 Optical Link A20B-0120-C05?/MAR 9" Monochrome CRT/MDI for "M" Operator Panel: FANUC 44C741056-G01 w/pulse coder / jog handwheel I understand that the mainboard is a conventional type so I cannot use the Alpha amplifiers. I would love to know if I have this configured right as well as someone who could tell me which of the power supplies I will need. Is there a lager backplane the 4 or 6 seems common. |
| I am almost finished with the hardware portion of this control. I also found enough parts to put together a 6slot 16M Model C order #A02B-0222.-B50x. The only thing I need to find out is the parameters that set up the A02B-0120-C051/MAR 9" CRT/MDI unit. Plus set up the three A06B-6079-H105 amplifier set. What cables and parameters ate needed? |
| Bridgeport CNC Series 1 vs Series 2 | jshank | Bridgeport and Hardinge Mills | 27 | 05-26-2012 08:51 AM |
| Multicam 3000 Series vs AXYZ 5000 Series | adamfilip | Commercial CNC Wood Routers | 1 | 10-18-2010 02:54 AM |
| Series 2 cnc 2 hp motor on a series 1 bridgeport? | CATCH22 | Bridgeport and Hardinge Mills | 1 | 11-08-2008 08:18 AM |
| What is the Difference between 6000 series aluminium and 7000 series | Kosta1234 | General Material Machining Solutions | 3 | 11-19-2005 08:04 AM |
