G73 is used to rough a uniform contour of a known thickness. G73 U___ W___ (U is amount of stock in X, W is amount of stock in Z) R is how many passes you are going to remove this with, assuming 8 mm for U and W you might choose R3 G73 P(start)Q(end) U(finish allowance x)W(finish allowance z)F(feed) is all you need..You need to start the cycle from a place where any return moves will not crash through your work..Hope that helps.. |
i will try and reply u. |
| You still haven't stated the model of the Fanuc control. If the control is pre "O" series, the G73 cycle command will be a one block designation with different addresses used to set various parameters. Regards, Bill |
| Heidenhain iTNC 530: Using Cycle 19 and Cycle 8 | Dan B | General CNC (Mill and Lathe) Control Software (NC) | 4 | 08-27-2011 11:32 AM |
| Canned Cycle Help | vanbry | Okuma | 14 | 12-14-2009 05:48 PM |
| Engraving Cycle | kia94 | General CNC (Mill and Lathe) Control Software (NC) | 2 | 12-11-2008 10:55 PM |
| G84 & G74 tapping cycle | Karl_T | G-Code Programing | 8 | 12-01-2008 07:52 AM |
| G76 CYCLE | BAD DOG | General Metal Working Machines | 2 | 09-20-2008 04:33 PM |
