Old 12-21-2010, 02:00 PM
ltx8d is on a distinguished road
Question Ethernet board for fanuc 21i MB controller
Hi, guys, I am working a project involving a Fanuc 21i MB controller. for Ethernet connection, do I need to purchase a ethernet board? I heard that there is an Ethernet port on the controller already. but I cannot find it.
Thanks for your help
Rag-Bear
Old 12-21-2010, 03:11 PM
FANUCCNC is on a distinguished road
Frist you need to determine if it is an "LCD-Mounted" CNC or a "standalone". If it is LCD-mount, the CNC is completely mounted behind the LCD screen, and only the drive system is mounted in the electical cabinet. The standalone CNC has a separate display and CNC and the CNC is most likely mounted in the electrical cabinet with the drives.
If you cannot find the CNC in the electrical cabinet (A02B-0285-B801 or A02B-0285-B803), then it is likely that it is an LCD-mount.
The Ethernet port on the LCD-Mount is on the motherboard mounted behind the LCD screen. On the standalone in is in the front of the yellow box in the electical cabinet.
Old 01-14-2011, 02:57 PM
Thanks for the reply. I took some pictures of the controller. but I donot know which one is the Ethernet port.does it like a usual one? also do I need to open the yellow plastic cover to access the port. here are some of the pictures:
http://img412.imageshack.us/i/photo0204f.jpg/
http://img254.imageshack.us/i/photo0211c.jpg/
http://img39.imageshack.us/i/photo0209e.jpg/
http://img121.imageshack.us/i/photo0206w.jpg/
Thanks a lot
Rag-bear
Old 01-14-2011, 05:19 PM
Scottjit is on a distinguished road
ImageShack® - Online Photo and Video Hosting
Thanks a lot
Rag-bear
In the picture 209e can you see on the bottom of the board, left side, does it say ethernet or network and not have a plug there? I know on the 0i there was a blank spot on the board where they did not solder on a connector, no network. If not open the yellow cage and look for a RJ40 connector mounted on the board. if there is not one then you will have to order the option.
Need Help!- Ethernet Fanuc 18i-TB ProToZyKo Fanuc 13 11-30-2010 07:10 AM
Is ethernet controller support with linux possible? Menatep General Electronics Discussion 3 04-25-2010 07:29 PM
Fanuc OM ethernet connection Porknar Fanuc 4 09-25-2006 09:11 AM
Haas Ethernet Circuit Board cncguy1200 Haas Mills 3 08-23-2005 03:00 PM
Controller parallel port connected via Ethernet (?) WoodSnarfer General Electronics Discussion 3 11-20-2004 03:48 PM
