Old 12-21-2010, 06:04 AM
yanhongnanbk is on a distinguished road
Exclamation Gcode to create hexagonal using Winnc GE fanuc 21M(c)
hi everyone can you help me in this problem?
My mission is to make a code to create a hexagonal as figure above using Winnc GE fanuc 21M(c)(Milling machine) .I dont know how to program this one. The cutting tool is always vertical to the x axis. I tried using G7.1 to make the workpiece turn an angle but in this case the Y axis is useless also after a G7.1 block the workpiece turn back to the initial position . So anybody can help me in this problem?
thanks you
sorry for my bad English grammar
Old 12-21-2010, 11:05 AM
kcho is on a distinguished road
You need a Fourth Axis.
Old 12-21-2010, 07:29 PM
hic I already use 4th axis but the cutting tool is always vertical I dont know how to change the direction of the cutting tool. is there any code to change the direction of the cutting tool
Old 12-22-2010, 12:57 AM
angelw is on a distinguished road
If the machine in question is a conventional three axis vertical machining center with a separate fourth axis installed on the table, and whose center line axis is parallel to the X axis, there is no way to change the direction the tool points, save that you use an angled tool holder with an internal mechanism to transmit the rotary motion of the main spindle to the tool.
I can’t make out the length of the shaft in your attached drawing, but you have two choices to machine the hex.
1. If the shaft is short enough to mount vertically, then the hex can be profiled by the tool moving on a hexagonal path.
2. If the shaft is too long to mount vertically, the shaft is mounted horizontally; employing the fourth axis to rotate the part 60 degrees after each flat has been machined to allow the machining of all subsequent flats.
Regards,
Bill
Need Help!- WinNc 3.1 File Format whiteredline General Metal Working Machines 7 02-13-2012 10:02 AM
Is WinNC required for CAD/CAM? Miguel.Hermanns EMCO CNC machines 8 01-04-2011 04:48 PM
WinNC jotaba Spanish CNCzone 8 12-14-2010 05:43 PM
Problem- FANUC GCode from SolidCAM Jixxer G-Code Programing 2 09-04-2009 01:52 AM
I have a problem with my gcode or my conversion to gcode , everything is tiny? NickLatech G-Code Programing 0 03-10-2005 12:46 PM
