Old 12-20-2010, 07:46 PM
47MLB is on a distinguished road
Fanuc OTC C axis program help
I need help with this section of code it is a live tool drilling a .125 dia hole three rows of three.
The chuck takes a little to find its zero to start. Left right a couple times then it stops . the drill comes in to drill three looks go so far then when it is time to brake release move 45 degrees it does a momentary may be move but does not and drills the second set in same line of first set linear row of five very close holes. Then for the third set of holes it does move 45 degrees and drills three holes like supposed to ?
I am pasting below. When I get this going I can add rows of hole change / add degrees of holes etc.
It is a AMERA SEIKI 2C 2L Fanuc series OT version C with C axis. Turret is a baruffaldi turret wit VDI 30 tooling.
Can you tell or show me what to fix in the below code?
Thanks Clint
T0303
M73S2000
M19
G28B0.0
M37
G0Z-1.150M8
G0X1.100
G98G1X0.250F15.0
G0X1.100
G0Z-1.400
G1X0.250F15.0
G0X1.100
G0Z-1.650
G1X0.250F15.0
G0X1.100
M38
G0B45.00
M37
G0Z-1.525
G1X0.250F15.0
G0X1.100
G0Z-1.275
G1X0.250F15.0
G0X1.100
M38
G0B90.0
M37
G0Z-1.150
G1X0.250F15.0
G0X1.100
G0Z-1.400
G1X0.250F15.0
G0X1.100
G0Z-1.650
G1X0.250F15.0
G0X1.100M9
M38
M75
G0G28U0.0
G0G28W0.0
Old 01-03-2011, 11:54 PM
Well I am making progress on the C axis.
the Amera Seiki service engineer looked over my parameter list and found that the C axis parameters were erased.
Now he is researching the correct ones to get it going.
I sholuld hear back int he next day or two.
47MLB
Old 02-21-2011, 09:07 AM
I found that this machine does not have full C axis. it has simple indexing only with live tools. it is called B axis and to input the degrees 11.377 = 1 degree
Amera seiki imported some machines that had live tools suposedely with full C axis so every one who had this machine in the past thought something was wrong with it as did I. I got lucky finding the person who said I remember that machine let me check the serial number. He gave me the rest of the story about this machine.
now I know it's limitaions no fancy snake or spiral fluting for me.
Old 02-21-2011, 09:10 PM
stevo1 is on a distinguished road
Sorry to hear that you did not get what you were expecting. However thank you for coming back and posting your update/resolution.
Stevo
Old 06-18-2011, 02:19 AM
Smile Fixed the B axis
Well on this lathe it is called B axis.
You do not see it on the screen like you would a true C axis on the position screen
I found it by playing in MDI mode giving the chuck simple 90 degree increment commands until it moved right
I am frustrated with Amera Seiki they never did come up with the solution.
to give say one degree in is B0.0001
For 90 degrees you need to enter B0.0090
I have been drilling holes and milling with my live tools now.
Now it would be cool to do a spiral like a five start thread say 1 turn in 10 inches using the live tool and a 5/16 ball end mill on this Fanuc OT-C control
Clint
PROGRAM ZERO ON FANUC M mousongie CNC Machining Centers 6 12-28-2010 08:24 PM
How to run a program under Fanuc 6TA samiahmed Fanuc 1 03-16-2010 06:22 AM
Need Help!- how to load a program in fanuc 6t? yumuri Fanuc 4 02-26-2010 02:02 PM
New program on Fanuc 6t? pob198 Europe Club House 2 01-14-2010 03:31 AM
FANUC 6M Program format Moolvie Fanuc 3 10-07-2005 09:37 PM
