Old 12-19-2010, 08:04 PM
Daniel Boone is on a distinguished road
fanuc ot g96 overspeed
I have a lathe with fanuc ot and it does not seem to correctly be reading the diameter of the stock correctly and when in g96 constant surface speed it tends to overspeed or alarm out. Any ideas? Thanks
Old 12-19-2010, 11:20 PM
kcho is on a distinguished road
you must use g50 S**** so you can limite the spindle speed.
Old 12-20-2010, 10:41 AM
I do use g50 and it still errors out.
Old 12-20-2010, 11:43 AM
Please give us more data about your machine, spindle amplifier type, cnc type, iso program....
Old 12-23-2010, 11:21 PM
sinha_nsit is on a distinguished road
Try invoking G96 after bringing the tool near OD of the workpiece. And cancel it before sending the turret to home position.
Old 12-24-2010, 02:14 AM
dcoupar's Avatar
post your program, please
Old 12-26-2010, 11:42 AM
EECENOD is on a distinguished road
THE PROGRAMMING LOGIC OF G96SXXXX MEANS NOT SPEED BUT SURFACE FEET
THAT IS IF I PROGRAM G96S600 AT A SPECIFIED RADIUS FROM CENTERLINE THE
SPINDLE WILL ATTEMPT TO MAINTAIN 600 SURFACE FEET..... AT .0001 FROM CENTERLINE
VECTORING THAT OUT WOULD RESULT IN MILLIONS OF RPM.
Old 12-26-2010, 01:31 PM
dcoupar's Avatar
EECENOD,
This is already established. The G50 Snnnn should limit the RPM to nnnn, but it's not, hence the reason for Daniel Boone's original post.
Old 12-26-2010, 01:33 PM
dcoupar's Avatar
Any possibility that your control is set up to use G-code system B or C, which use G92 Snnnn to specify the maximum RPM during G96 mode?
Old 12-26-2010, 01:36 PM
Al_The_Man's Avatar
Is there a possibility the spindle encoder is giving problems or where driven from a small timing belt, belt slip or failure could be the problem.
  #11   Ban this user!
Old 12-30-2010, 09:18 PM
cncserveng is on a distinguished road
Its not just overspeed, underspeed can cause issues also.
you need to set min and max speeds, i.e. P 200 Q2000.
Have you tried G92 ?
  #12   Ban this user!
Old 12-31-2010, 09:18 AM
dcoupar's Avatar
In all my years of programming Fanuc controlled lathes, I've never seen a command to set minimum RPM. Please explain the use of P200 and Q2000 to set min and max speeds.
GE Fanuc & FANUC proprietary posts CNCadmin Fanuc 44 01-05-2012 08:54 AM
can fanuc ac digital servo amplifiers be run by a controller other than fanuc? js412000 Servo Motors and Drives 5 03-09-2011 09:11 AM
Overspeed your spindle bearings? Frogblender Benchtop Machines 1 12-16-2009 03:26 PM
Can I safely overspeed a Baldor motor? loesch Phase Converters and VFD 32 07-02-2007 11:57 PM
