Old 12-13-2010, 03:18 PM
billquinn1 is on a distinguished road
PMC setup for FAPTIII
This is my first day here and my first post so here goes.
Fanuc Powermate D PMC-PA3
FAPTIII V5.7
I have read a dozen or so posts on getting FAPT to work with various controls. They all talk about settings on the PMC screens that I don't have. I have tried every setting in the PMC I/O area I can think of. The one that seems most likely Is
"CHANNEL 1"
"DEVICE HOST"
Every thing else blank, make the settings under "SPEED" The same as the software, and hit "exec".
FAPT says "COM PORT 4 CONNECTING" ... "DISCONNECTING"
If anyone has any experience getting this to work, I would be eternally gratefull. I really don't want to have to make the number of changes I need to make with the Ladder edit card.
Thanks,
Bill
Old 12-13-2010, 07:14 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
ladIII
has two ways of connecting
1. Ethernet.
2. RS232
option 1 all you need to do is enable High speed communications on the monitor page and set all the ethernet IP settings in the appropreate section on
SYSTEM -> + -> + -> + -> ETHER
Option 2 all the RS232 settings must be set correctly, use channel 0 or 1 and the cable is a standard Fanuc RS232 then connect on LADIII
This is where all the PMC LADIII setting are on the CNC
SYSTEM -> PMC -> MONITOR
if you cannot see this page, most likely you will need to enable the progamming setting
SYSTE -> PMC -> PMCPRM -> SETTING ->
if you don't know about these pages I would advise you don't mess with changing PLC's!
Best Regards
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 12-14-2010, 06:56 AM
Originally Posted by MysticMonkey View Post
ladIII
1. Ethernet.
2. RS232
Best Regards
Thank you for your reply.
SYSTE -> PMC -> PMCPRM -> SETTING -> does not have any related settings just something about "BCD OR ASCii".
After spending 8 hours on this yesterday, I am almost convinced this particular version of Powermate / PMC does not have the "MONITOR" section. The other option is the same I have been trying and that is that some parameter needs to be set.
I will continue to look for answers / advice.
If I find my answer, good or bad, I will post back here in case it helps someone else out.
Thanks again,
Bill
Old 12-14-2010, 10:43 AM
Fanuc Mate's Avatar
Fanuc Mate is on a distinguished road
It should be [SYS] {pmc} {>} {>} {>} {MONITOR}
Try setting K17.1 to a 1. It might cure it, but i can't remember. It enables editing etc of the PMC.
CNC Mate
www.cncmate.com
Old 12-14-2010, 11:17 AM
I have k17.1 set to 1. This machine does not have online edit. You have to use a "Ladder Edit Card". I will try [SYS] {pmc} {>} {>} {>} {MONITOR} with the card inserted after the machine stops production for the day. I can't say I tried pressing the soft key 3 times. Its worth a shot.
Thanks,
Bill
Old 12-15-2010, 12:11 AM
If this machine needs an extra card to display the ladder.
I very much doubt it has the option to monitor the PLC remotely
your best option is to extract the ladder then modify it offline.
then upload it back to the cnc
files are form the B-62835/01.pdf Maintenance manual
just choose channel 0 or 1 and up/down load like a normal file
Old 12-15-2010, 09:19 AM
Yes that appears to be an option. After discussions with another forum member, I have the correct method for my control. It involves using "IO by IO" setup. After I have successfully completed the entire process I will post a brief summary of the procedure.
Thanks,
Bill
Old 12-19-2010, 10:46 AM
Ok, I have completed my project using FAPT III.
1. Make a new "dummy" program with the correct PMC version.
2. Go to "Tool" > "Load From PMC"
3. Select "IO by IO" > "Load From PMC" > "ladder"
4. Set the com setting same as PMC IO "SPEED" settings.
5. On PMC IO screen set "Channel 1" (my case) > "host" (nothing else) Press "exec".
6. Click "Finish" on last screen of software.
Reverse (basically) to write to PMC.
These very brief instructions are for my PMC type (PA3) and may not work for another type.
You should refer to Fanuc manual B-6634en/06 for more info and thanks to CNC2149 for filling in the blanks.
Bill.
What do you think about this setup? Grp Racing Benchtop Machines 25 04-17-2009 05:30 AM
Newbie- Need Help With Setup compmedic LinuxCNC (formerly EMC2) 25 02-08-2009 01:01 AM
New Machine Build- Need help with setup LaserImage Stepper Motors and Drives 25 07-18-2008 01:25 PM
What's your setup like... Scratch CNC Plasma and Waterjet Machines 1 01-12-2007 01:31 PM
Setup i need help k-linkz Hobbycnc (Products) 3 08-07-2005 08:11 AM
