Results 1 to 7 of 7
Thread: Leadwell V-30 Fanuc 21-M Drip Feed
    Dec 2010
    Hi Everyone ,
    I need some help running dnc on my new leadwell V-30. I pretty much am having the same problem as everyone else not being able to find out how to activate the dnc. The controller is a Fanuc 21-M with no TAPE button on it. I know that this machine can do it , because the last owner did, but apparently doesn't remember how. I can send and receive no prob but can't drip feed.
    Can anyone help.
    Thanks '
    Danny
    Registered resuengineering's Avatar
    Nov 2007
    Netherlands
    Do you have RMT on your rotary switch, also where jog / ref etc. etc. is?
    otherwise most times you can set a diag bit, for drip feed.
    but does the fanuc have a PCMCIA port on front???
    Dec 2010
    Nope , no RTM switch or TAPE switch , No card in the front of the panel either , just the rs232 in the back of the machine. Apparently i have to change some parameters to be able to run it DNC. What is a diag bit ?
    Nov 2007
    Netherlands
    diag bit = diagnose bit
    Nov 2007
    Netherlands
    you could try this
    To set the CNC up for drip feed:
    Parameter Value
    0135 00000001
    1803 00000000
    To set "Tape mode" on.
    Send the program from the computer, then press Cycle Start on the Fanuc.
    To pause dripfeed, turn the Feedrate override to 0%.
    Sep 2010
    Quote Originally Posted by resuengineering View Post
    you could try this
    Parameter Value
    0135 00000001
    1803 00000000
    In DNC (drip feed) mode, all functions of the control such as Single Block, Block Delete, Optional Stop, and Feed Hold all work as per normal. Accordingly, if you want to pause the program, just press Feed Hold.
    Regards,
    Bill
    Registered dcoupar's Avatar
    Mar 2003
    Quote Originally Posted by Neutronix LTD View Post
    Hi Everyone ,
    Can anyone help.
    Thanks '
    Danny
    Danny,
    I don't know if this applies in your case, but I recently ran into a machine (Femco, I believe) that had DNC mode switch hidden in the Software Operator's Panel.
    If you go to OFFSET/SETTING, then press the > key until you see [OPR] and press that, you might find it there. Page down may reveal more switches. No guarantees...
    1. Fanuc 10M - Drip Feed
      By Swemill in forum Fanuc
      Last Post: 10-02-2012, 05:36 PM
    2. WSC-6 fanuc 0T-B Drip Feed
      By dexta in forum CNC Machining Centers
      Last Post: 02-27-2011, 03:20 AM
    3. Drip feed for Fanuc 0-MF
      By giorgis in forum Fanuc
      Last Post: 05-08-2009, 11:44 AM
    4. Need Help!- Fanuc 6mb drip feed
      By cowleym in forum General Metal Working Machines
      Last Post: 03-18-2008, 06:25 PM
    5. Drip Feed - DNC - Fanuc 16i
      By gm3211 in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 09-21-2007, 03:43 PM
