Old 07-11-2005, 03:35 PM
wild01 is on a distinguished road
mazak v-5 w/fanuc 6m control nc fuse light??
ok here goes anyone out there w/a fanuc 6m controller on a mazak v-5
on mine there are a row of malfunction lights on the front panel
the first one is labeled "nc fuse" when I turn the control on (front button after side breaker" it powers up fine and then after 20 or so minutes the screen turns off and the nc fuse light comes on.
this used to be a rare intermittent problen that came up about once a month, but today it decided to start faulting every 10 to 20 minutes.
the operators manual has this to say "nc fuse alarm" alarm for nc fuse blown out- the display lamp lights if the fuse is blown out-check whether the nc fuse is blown out. if the fuse is not blown out, there is some trouble in the unit.
no S___ sherlock!
h btw yes I did check all the fuses in the nc cabinet, and for that matter every fuse I could find on the whole friggen machine. no luck.
anyway, if one of you has come across this problem your help and experience will be greatly appreciated thanks in advance.
Old 07-11-2005, 04:08 PM
Al_The_Man's Avatar
Do you have a print that shows exacly what the indicator light is monitoring? One thing I would check to see if the DC power supply is OK. It is usually mounted close to the Main board.
Old 07-11-2005, 05:05 PM
thanks al one of my other gurus already rescued me
the power supply voltage was 4.8 and needed to be turned up to 5.2
works like a charm now.
well so far anyway :fingerscrossed:
mazak v5 micrcenter w/ fanuc 6m b dnc?? wild01 Machine Problems, Solutions , Wireless DNC, serial port 4 12-23-2010 08:06 PM
PC input/control with Fanuc 5 jevs Fanuc 7 10-21-2008 10:49 PM
Did Anyone hear of "Spectra Light Mill Control"?? CNCNR General Metal Working Machines 2 01-22-2008 06:28 PM
mazak v5/fanuc 6mb tool changer mastercam post edit wild01 Post Processor Files 1 10-26-2006 09:44 AM
fanuc tool change prompt light cam Machine Problems, Solutions , Wireless DNC, serial port 0 04-02-2004 09:27 AM
