Old 12-07-2010, 02:50 AM
cnc-it's Avatar
cnc-it is on a distinguished road
Hitachi Seiki 4NE11 with blank 9" CRT
Hi I have an Hitachi Seiki 4NE11 cnc lathe with Fanuc 6TB.
It's a new project and i'm trying to get it up and running after a year in storage.
All seems well but the 9" green crt is not lighting up after I switch on.
The X Z axis are working fine and will jog around no problem and the hydraulics hums away like it's never been switched off but without the screen I can't home or check any diagnostics.
It has a Micon 8 controller on the back cabinet which seems to be working fine. All the alarm codes are ok apart from 28A which has a 1 in each address space refering to 100v, 24v and 12v power supply issues (the manual is in in Jinglish so not very clear!)...might be because it isn't homed yet?
All the power supplies seem fine in the drive cabinet...no error led's etc.
Thanks for any help guys.
John
Old 12-07-2010, 09:58 AM
underthetire is on a distinguished road
I believe there is a power supply board mounted to the left of the CRT, is that one working?
Old 12-08-2010, 02:57 AM
cnc-it's Avatar
Hi will check that today. The manual says check for 12v between the fuse and 0v but not sure which pin on the edge connector is 0v. The crt has an orange light(tube heater?) on the back so presume power is getting to it.
Thanks John
Old 10-29-2011, 04:44 PM
cnc-it's Avatar
Just to update. Swapped the old crt for a new unit found on Ebay. Screen works fine now.
Old 10-29-2011, 06:50 PM
tc429's Avatar
tc429 is on a distinguished road
just a note-
a LOT of 9" monitor failures can be fixed with just a soldering iron... the board on the side of the control has a kinda circular pin pattern where the flyback mounts- seen MANY with little round cracks around those pins...just the weight of the transformer/vibration will cause cracking in the solder. probably at least 2/3 of our 9" monitor problems could be repaired by simply remelting those pins to reconnect them.
bad solder joints often pop up with bright or dark screen, sometimes thumping the panel will make it flicker too...resolder those pins, it usually works fine.
Old 10-29-2011, 08:41 PM
cnc-it's Avatar
Thanks will check the old screen unit might be able to repair it and keep as a spare
John
Need Help!- fANUC 6T "HITACHI SEIKI" yumuri Fanuc 1 01-12-2010 04:22 PM
Need Help!- fanuc 6T "HITACHI SEIKI" yumuri Fanuc 4 01-12-2010 12:26 PM
Need Help!- fanuc 6T "HITACHI SEIKI" yumuri Fanuc 4 10-31-2009 10:38 AM
NEED cast iron blank 7"x1.5" captainlee General Metalwork Discussion 5 07-03-2008 01:54 PM
