Old 12-06-2010, 10:27 PM
istotel is on a distinguished road
new program
powermate D controller
1)additional new program:-
-now this machine have 3 program(o0001~o0003)
-i need create new program(o0004 and o0005)
-program call with selector switch
2)what i need to do?
Old 12-07-2010, 09:37 AM
dcoupar's Avatar
Type O0004 then press the INSERT key.
Old 12-08-2010, 08:14 AM
i know how to create new program.
but how to call this new program?
need i create new ladder for call new program?
Old 12-08-2010, 08:23 AM
Perfect Circle's Avatar
Perfect Circle is on a distinguished road
In edit mode (type program number) then hit arrow down key, thats how most fanucs I know work.
Old 12-08-2010, 10:52 AM
sinha_nsit is on a distinguished road
I type program number (with or without O) and press O SRCH soft key.
Old 12-08-2010, 03:54 PM
msa msa is offline
msa is on a distinguished road
If you post the PMC and an image of the selector switch. the I'll tray have closer look.
Old 12-08-2010, 07:48 PM
gbowne1 is on a distinguished road
What exactly is the "Power Mate"? I've seen them, heard about them but.. don't know much more about them.
Old 12-09-2010, 09:05 AM
cnc2149 is on a distinguished road
Power Mates are usually a single or dual axis control (very similar to CNC) usually controlling auxilliary axes or motion on a non-CNC machine (e.g. T shirt printing machine). They also used to be used for auxilliary axis control (e.g. tool changer) on some older CNC controls. The Power Mate H and iH actually can handle up to 6 axes, though. In the case of a Power Mate D, it supports 1 axis (2 optionally) and up to 1 spindle. Can make a small drill machine out of it or any other simple motion application. The Power Mate D uses S-Series, C-Series, or alpha amplifiers/motors, depending on vintage and configuration.
Many of the Power Mates don't have a typical CNC machine type operator panel. The OEM often minimizes the no. of operator devices and some are set up to only select few part programs, as in isotel's posted message. They would use the Workpiece Number Search PMC signals (G-bits) to call up a specific part program. So, in order to add more part program selections, the PMC logic would normally have to be edited. Not technically difficult, but you'd have to have the appropriate equipment. It is much easier to edit the PMC Ladder on the PowerMate D if it already uses an LCD or CRT interface. Can also edit the ladder if they only have the DPL/MDI unit but it is a beating. Best to edit the PMC Ladder offline and transfer it via RS232 if it does not have the LCD or CRT unit.
As with most PMC changes, the most important thing is that they'll need to engage someone with knowledge of FANUC PMC development that also has access to the correct development equipment in order to implement the changes requested.
tl-2 program integrity error and program data error alarm #'s 212 250 need help CNChelp Haas Mills 12 03-14-2010 08:19 PM
Mazatrol Program into a G Code Program fuzzman Mazak, Mitsubishi, Mazatrol 14 02-08-2010 03:55 PM
Program Restart in mid program? Donkey Hotey Haas Lathes 16 03-18-2008 02:19 PM
what program do i need? jc286006 DIY-CNC Router Table Machines 1 01-04-2006 11:16 AM
Anyone got any basic examples of a program using a subroutine/program? Darc CamSoft Products 11 10-08-2005 11:45 PM
