Originally Posted by
dangittj
We have a Tsugami S25 SuperSwiss Turn lathe with a Fanuc Series O or OO Controller that we moved to one of our other facilities and it stopped working.
The machine is connected to the computer using a regular 25 pin parallel cable over LPT1, using an old version of ProComm to send the files.
Im not sure how this worked originally, as ProComm can't even send over the parallel port. The machine was just boxed up and sent out, no configuration changes were made as far as I can tell. All the operators have said it's the exact configuration, but i can't figure out how in the hell it worked before and how to get it to work. The cable they have given me is the same one they used in the original facility, and it is not bad, I have hooked it up to a cable tester and it is working.
I have tried using a null modem adapter and a 25-9 serial converter (working on the theory that maintenance lost them in the move) but both of these combinations cause the controller to immediately error out like it is not connected.
Any help would be greatly appreciated.
