| Hi all! I hope some of you can help me deal with a problem I get when I make a program in Custom Macro A for a Fanuc O-MD, 3-axis milling machine. My problem is that when I try to run my program (posted at the bottom) I get alarm 076 address P not defined. I have tried to define my P#values both at the main program, in variables definition of main program and later I tried to define them in the subprogram. Neither seemed to get rid of the problem, and since I haven’t been able to find much help on macro A I seem to be stuck. ![]() The program has to drill 9 holes (3x3) in each of 8 parts that are lined up as 4x2 I am new to CNC programming so it might be some very basic knowledge I’m lacking. I really hope someone can help! Thanks! Regards, Lene Madsen O0010 Main program G17 G40 G54 G21 G90 ; M6 T1; G00 X0 Y0 Z0,5 S400 M13; G65 H01 P#121 Q4000 G65 H01 P#122 Q4000 G65 H01 P#123 Q8500 G65 H01 P#124 Q8500 G65 H01 P#125 Q3 G65 H01 P#126 Q3 G65 H01 P#127 Q0 G65 H01 P#128 Q0 G65 H01 P#129 Q2 G65 H01 P#130 Q2 G65 H01 P#131 Q25000 G65 H01 P#132 Q25000 M98 P1010 G00 Z100; G00 X0 Y200; O1010 Custom macro A G65 H01 P#101 Q1 G65 H01 P#102 Q#128 N1 G65 H83 P99 Q#101 R#130 G65 H01 P#103 Q1 G65 H01 P#104 Q#127 N5 G65 H83 P80 Q#103 R#129 G65 H01 P#105 Q1 G65 H01 P#106 Q#122 N10 G65 H83 P75 Q#105 R#126 G65 H01 P#107 Q1 G65 H01 P#108 Q#121 N15 G65 H83 P50 Q#107 R#125 G81 X#108 Y#106 R0,1 Z-13,1 F50 G80 G65 H02 P#107 Q#107 R1 G65 H02 P#108 Q#108 R#123 G65 H80 P15 N50 G65 H02 P#105 Q#105 R1 G65 H02 P#106 Q#106 R#124 G65 H80 P10 N75 G65 H02 P#103 Q#103 R1 G65 H02 P#104 Q#104 R#131 G65 H80 P5 N80 G65 H02 P#101 Q#101 R1 G65 H02 P#102 Q#102 R#132 G65 H80 P1 N99 M99 I first created the program in macro B (I was advised to do so, but I had ofcourse no way of testing this) #24 X 4 #25 Y 4 #21 U 8,5 #22 V 8,5 #23 W 3 #11 H 3 #1 A 0 #2 B 0 #3 C 2 #7 D 2 #8 E 25 #9 F 25 O0010 Main program M6 T1; G17 G40 G54 G21 G90 ; G00 X0 Y0 Z10 S400 M13; G65 P1010 X4 Y4 U8,5 V8,5 W3 H3 A0 B0 C2 D2 E25 F25 ; G00 Z100; G00 X0 Y200; O1010 Custom macro B G00 X#24 Y#25 #121 = 1 #122 = #2 N1 IF[#121 GT #7] GOTO 99 #131 = 1 #132 = #1 N5 IF[#131 GT #3] GOTO 80 #111 = 1 #112 = #25 N10 IF[#111 GT #11] GOTO 75 #101 = 1 #102 = #24 N15 IF[#101 GT #23] GOTO 50 G81 X#102 Y#112 R0,5 Z-13,5 F50 G80 #101 = #101 + 1 #102 = #102 + #21 GOTO 15 N50 #111 = #111 + 1 #112 = #112 + #22 GOTO 10 N75 #131 = #131 + 1 #132 = #132 + #8 GOTO 5 N80 #121 = #121 +1 #122 = #122 + #9 GOTO 1 N99 M99 Last edited by Lene Madsen; 11-30-2010 at 05:37 AM. Reason: added macro B program |
| Dear Lene, Could you tell me result of try as follows(Delete or skip M,S,T code and insert M30 at the end of Main program). (M6 T1); (G00 X0 Y0 Z0,5 S400 M13); . . . G65 H01 P#132 Q25000 M98 P1010 G00 Z100; G00 X0 Y200; M30 Daecheol Sung |
| O0010 Main program G17 G40 G54 G21 G90 ; M6 T1; G00 X0 Y0 Z0,5 S400 M13; G65 H01 P#121 Q4000 G65 H01 P#122 Q4000 G65 H01 P#123 Q8500 G65 H01 P#124 Q8500 G65 H01 P#125 Q3 G65 H01 P#126 Q3 G65 H01 P#127 Q0 G65 H01 P#128 Q0 G65 H01 P#129 Q2 G65 H01 P#130 Q2 G65 H01 P#131 Q25000 G65 H01 P#132 Q25000 M98 P1010 G00 Z100; G00 X0 Y200; M30 O1010 Custom macro A G65 H01 P#101 Q1 G65 H01 P#102 Q#128 N1 G65 H83 P99 Q#101 R#130 G65 H01 P#103 Q1 G65 H01 P#104 Q#127 N5 G65 H83 P80 Q#103 R#129 G65 H01 P#105 Q1 G65 H01 P#106 Q#122 N10 G65 H83 P75 Q#105 R#126 G65 H01 P#107 Q1 G65 H01 P#108 Q#121 N15 G65 H83 P50 Q#107 R#125 G81 X#108 Y#106 R0,1 Z-13,1 F50 G80 G65 H02 P#107 Q#107 R1 G65 H02 P#108 Q#108 R#123 G65 H80 P15 N50 G65 H02 P#105 Q#105 R1 G65 H02 P#106 Q#106 R#124 G65 H80 P10 N75 G65 H02 P#103 Q#103 R1 G65 H02 P#104 Q#104 R#131 G65 H80 P5 N80 G65 H02 P#101 Q#101 R1 G65 H02 P#102 Q#102 R#132 G65 H80 P1 N99 M99 |
| I answered your post last night, but I don't see it here this morning. Not sure what happened there. Anyway, the format you're using to define P is correct with User Macro A. In the following example, P would take on the value of Q, being 4000 G65 H01 P#121 Q4000 When a program contains macro statements, and the control alarms for no obvious reason due to something related to the Macro statements, try isolating a line of code that the error message relates to, in a program by itself and try running it. For example, construct the following program and run it. O1000 G65 H01 P#121 Q4000 M00 M30 % 1. If the program errors and displays the same error message that you have been experiencing, then you have an issue with the control because the code in the above program is viable. 2. If the program runs without an error, and when it stops at the compulsory stop M00, look up variable 121 in the Macro variable register and check that the value 4000 has been stored in the corresponding variable. 3. Continue to add to this program one block at a time, the blocks from your original program, but include the M00 just before the end of the program. 4. After each inclusion of the additional block, run the program to see if you get the error and check the variable as in point 2 above. This may sound a bit tedious, but when you have an error situation that is occurring for no obvious reason, this is a good way of finding the cause, particularly when the program is relatively short as yours is. Please post the result if you decide to run this test. Regards, Bill |
| Or if you are just learning CNC programming then you may want to use macroB instead. This is more current with machine programming then A. I am never against learning something no matter how old it is but it is definitely 2 breeds of programming and macroB will help you longer term. You will also find more support to B then A. I am taking nothing away from the people already helping and their suggestions. Sorry I know read the rest of your post with the macroB code. May I ask why you were advised to write this in macroB first? Can anyone tell that I hate macroA?? ![]() Stevo |
| Sung and Angelw: I will be trying both your suggestions once the machine is off duty, thank you very much both! Stevo1: The particular machine I am running only has the option to program in macroA. I was adviced to write in macroB since they mostly differ on syntax. Is that wrong? |
In the following example the two Macro statements have the same function, but the Macro B code is far easier to read. Macro A------------------------------Macro B G65 H02 P#101 Q#102 R15------------#101 = #102 +15 I can well imagine someone suggesting you write the program in Macro B, then transpose the Macro A function code to perform the same task, because of the better readability of Macro B. However, the same could be achieved by drawing a Flow Chart, which is the approach taken when designing software. The attached picture is an example of a flow chart just to illustrate how symbols, lines, and directional arrows can be used to show functions, conditional statement etc in a graphical, easy to follow form. Flow charts are often just quick hand sketches to allow you to better visualize the logic of your program. Regards, Bill Last edited by angelw; 12-07-2010 at 01:22 AM. |
| Tags |
| alarm 76, macro a |
| Custom Macro Containing G65 | LostInMacro | Fanuc | 21 | 09-15-2010 03:21 PM |
| Custom Macro B | rlgx4 | Parametric Programing | 7 | 08-02-2010 04:05 PM |
| "difference between Custom Macro A and Custom Macro B" | arulthambi | Parametric Programing | 4 | 10-05-2009 03:34 PM |
| Custom Macro B On A 18t. | JIMMYZ | Fanuc | 3 | 10-18-2006 10:08 PM |
| custom macro | The Metal | Daewoo/Doosan | 2 | 09-28-2006 07:26 AM |
