Old 11-29-2010, 10:54 PM
Antonio Arguijo is on a distinguished road
Fanuc O-T control
HELLO! I NEED HELP!!!
WE HAVE A JOHNFORD MACHINE WITH FANUC OT CONTROL, DRIVES SERIE ALPHA, WHEN WE START THE MACHINE SUDDENLY APPEARS ALARM 19 ON THE SPINDLE AMPLIFIER, AFTER THAT APPEARS THE ALARM 401 MACHINE NOT READY, SOMEONE KNOWS WHAT HAPPEN IT!!!
Old 11-29-2010, 11:59 PM
resuengineering's Avatar
resuengineering is on a distinguished road
Alarm 19 on Spindle driver means
Phase U current detector circuit excessive offset
Meaning,
The offset voltage for the phase U current detection circuit is too high,
this check is made after power on the machine.
Cause:
Loose contact of the PCB board - check connections
phase current detection defective. - replace PCB
A/D converter defective - Replace PCB
Also check the input power on the PSM module
Old 11-30-2010, 11:24 AM
Power not on
Thanks, but the power is not on, the main contactor not on, the alarm apeears 2 seconds, after that appears on the displays [-] but the power never goes on.
Old 11-30-2010, 02:32 PM
these checks are performed, when supplying power to PSM module
this has a seperate control bus power supply, no need to charge the DC Bus for this alarm
all phases are excisting??
you say no power, but no power means no display start up also!!!
Old 12-04-2010, 01:43 AM
Question Alarm 401 OT control FANUC
To be clear:
1.- Put on breaker 460 VAC
2.- on the display from Spindle Amplifier appears suddenly alarm 19, after that appears --
3.- On the screen appears NOT READY
4.- When I push the button OT Release appears Alarm 401
5.- MCC never go on
6.- on the display from PMS, and drives appears -- only
Help with Fanuc 6m control inaman Fanuc 5 02-03-2012 12:49 PM
Need Help!- Velocity Control Drives and Fanuc 2000C control redialtone Fanuc 3 06-21-2010 09:26 PM
Fanuc O-T control Antonio Arguijo Fanuc 7 06-20-2010 04:46 PM
FANUC OM CONTROL gabedrummin Fanuc 0 08-28-2008 04:41 PM
FANUC OT control need dnc help mike10 Fanuc 5 10-17-2006 03:27 PM
