Old 11-23-2010, 05:14 AM
shrirang is on a distinguished road
Fanuc 18M - 414 HCA Servo alarm only while cutting
We have a Kao Ming VMC with Fanuc 18M controller. I get a
414 Servo Alarm - X axis detect error. In the diagnostic parameter 200,
the HCA bit (bit #4) is 1 - which is abnormal current Alarm. The LED on
Servo glows with 9 (but it seem for HC it should be 8). Everything else does not have problem. The alarm comes only when there is actual cutting going on. Some time it comes soon after the cutting starts, some times it takes much longer. Spindle load is only around 50%. But if the program is run dry (just increasing the height so that there is no cutting), there is no problem. Once the alarm comes, it goes off (only) when the machine power is switched off completely. I also tried changing cutting direction. It does not have any effect.
What can be the problem?
Thanks,
Shrirang
Old 11-24-2010, 04:03 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
first thing to do is a coil insulation check on the motor windings.
then swap the servo amplifier with one of the other amplifiers.
if the alarm follows the amp then that is the fault.
if it doesn't then change the motor encoder.
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Tags
414 servo alarm, fanuc 18m, hca
Need Help!- Fanuc 6M - 401 Servo Alarm parametric.ms Fanuc 4 03-24-2010 12:02 AM
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 09:03 AM
fanuc servo alarm vpmachine Fanuc 0 11-07-2007 02:33 PM
Fanuc 6m 416 X Servo Alarm Yabbos Fanuc 7 08-20-2007 04:30 AM
Fanuc Servo Alarm herbmarkovit Fanuc 20 11-20-2005 10:53 AM
