Old 11-22-2010, 07:23 PM
metlcutr55 is on a distinguished road
fanuc 20-t monitor fail & symptoms
my nardini lathe fanuc 20-t mono green monitor started having a patch in the low lh area that was being illuminated by the crt gun looked like a cloud, fuzzy, soft edged, didnt obscure text, nums et al. over a week or so progressed to flashes and trails & "sparks". looked like a roman candle was brodcasting in the same area. grew bigger, but would sometimes pop back to a clean legible display. then the display would jitter, and have hot horizontal flashing lines across. it finally went out altogether, now that it has, the machine wont come on line, briefly brings up the good "0"'s on the amps then trips out with slashes, no code. dont want to blow a grand on a replacement lcd monitor without hearing some opinions from you folk who are electronically sharper than i, which would be most of you. thanks!
PC MONITOR FOR FANUC CHANDRU Fanuc 1 01-03-2011 01:25 PM
Need Help!- Fanuc monitor info Dave3891 Fanuc 6 11-03-2010 09:57 AM
Problem- 325 PROC WDT FAIL ramsey321 Tree 15 09-14-2010 10:47 AM
VF2 Turrent Fail jimmck Haas Mills 1 06-03-2009 11:50 AM
Lube Fail CC714 Fanuc 2 01-24-2008 10:39 AM
