Old 11-21-2010, 08:55 AM
mehdiF is on a distinguished road
problem running program
I lost the parameters on my fanuc OTF(C) turnning machine, after loading all parameters which I had on disk and paper, now when I want run program in auto mode or MDI the program stops at gcode (g01 or g00) without any massage meanwhile all other command like tool change spindle and coolant all is done. Can any body help me to find related subject or parameter.
Thank in advance
mehdif
Old 11-21-2010, 10:03 AM
sinha_nsit is on a distinguished road
Check overrides, axis interlocks, single-block switch etc.
Are you able to manually jog the axes?
Post your program.
Old 11-21-2010, 11:03 AM
sinha nsit
I checked all, problem exist.
Old 11-22-2010, 01:27 PM
sinha_nsit
Thanks for your help, there was DGN 484.0 parameter activating G120.1 as axis interlocked by changing the bit problem solved
Thanks again.
mehdif
Need Help!- Running program with G0, G1, and/per F Martcnc CamSoft Products 3 01-19-2011 12:46 AM
V2XT - RUNNING A PROGRAM WITH THE SPINDLE OFF DF-ENTERPRISES Bridgeport and Hardinge Mills 3 11-18-2010 09:53 PM
Need Help!- Starting mid program when running g-code, VTC200B naytep Mazak, Mitsubishi, Mazatrol 2 04-17-2010 12:24 AM
Newbie- Zoom graph while program running (18-T)? polarbeer Fanuc 0 07-19-2008 07:01 AM
Axis motors stop while running a program kevinkoons Mach Mill 1 05-22-2007 01:43 AM
